Old 03-16-2023, 11:07 AM #1
andynj andynj is offline
andynj is on a distinguished road
Spark Plug Socket Tool
Just did my spark plugs after 25k, they looked pretty good coming out but replaced them with a set of iridiums and it seems to have sorted a very slight flutter I used to get at idle.
Its not a hard job but took about 90 mins as I was being really careful removing the coils and stuff out the way to make sure nothing got damaged. The plugs on the coils are a pain to remove in such a tight space and a pick helps but I was afraid of snapping off the tab as that would turn the job into a nightmare. Also put some die electric grease in the coil for the top of the plugs and in the coil piugs to make things easier next time.
Anyway the first time I did this it was a pain as my spark plug socket kept disconnecting from the extension bar in the hole and I ended up having to tape it on to make sure it didn't get stuck. this time I got this tool and would highly recommend makes things 10x easier
https://www.amazon.com/dp/B07MH5ZDMD...roduct_details
andynj is offline   Reply With QuoteReply With Quote
Old 03-16-2023, 11:39 AM #2
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
This tool looks interesting. Does it make it harder to start threading the spark since the end swivels?
zguy1 is offline   Reply With QuoteReply With Quote
Old 03-16-2023, 03:56 PM #3
dexter_5000 dexter_5000 is offline
dexter_5000 is on a distinguished road
https://www.amazon.com/CTA-Tools-238...e%2C107&sr=1-8
this is similar to the one i have that i've used with success in the past. as there is nothing to let go either. just one solid socket.
dexter_5000 is offline   Reply With QuoteReply With Quote
Old 03-16-2023, 05:15 PM #4
d33pt d33pt is offline
d33pt is on a distinguished road
You can also get locking extensions too. Then you can use it for other purposes.
d33pt is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 09:16 AM #5
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
The swivel is essential to avoid cracking the porcelain. Im cheap by nature so I went shopping at ebay. Found a nice used snap on spark plug socket for $25. Love it. Magnet inside holds the plug and the swivel work great.
But make sure the BB on the extension goes into the socket where the hole is. Otherwise it can pop off. If there is no hole, drill one
Spark Plug Socket Tool-6a9cd6f4-1ffd-45ac-ab6a-311eefd3caf4-jpg
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 11:08 AM #6
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Originally Posted by andynj View Post
(snip..) Also put some die electric grease in the coil for the top of the plugs and in the coil piugs to make things easier next time.
Dictionary
Definitions from Oxford Languages
noun: dielectric
a medium or substance that transmits electric force without conduction; an insulator
I keep reading about people putting dielectric grease on spark plug tips and connectors. Dielectric grease is an insulator. High energy electrical systems do not need an insulator on the metal parts. It's going to cause problems. Dielectric grease is to be used on a spark plug rubber boot and ceramic area to prevent energy from going where it shouldn't and to make it easier to remove a boot from the spark plug. You can use it on a part that will not be conducting energy to the plug's metal tip where it connects to the plug wire, but not on anything metal. Make sure you didn't accidentally get any on the iridium tip either.
It's been a while since I changed my plugs and I remember removing the coil but I don't remember having any difficulty. Best to just clean up the area with a dry cloth and not use any grease. If you're getting misfires, clean off the dielectric and install the plugs again.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 02:26 PM #7
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
FWIW, iridium isn’t the OEM specified plug for the V6. Don’t know why but I trust Toyota’s engineers are better qualified than I am to determine such things so I change mine every 30K with the spec plugs.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 03:26 PM #8
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Yes this is true...at least for 4th Gens....until 2010 5th gens came out, then Toyota switched the plugs for the V6 to the Iridium plugs, which is why many 4th Gen V6 owners now install them in their V6.
The V6 engine I don't believe changed from 4th Gens to the 5th Gens, unless the ignition coils changed.
2004 Limited V8
Old 03-19-2023, 10:41 AM #9
Cuervo Cuervo is offline
Cuervo is on a distinguished road
I use this type of tool at work. I got it off the Matco truck as a kit. It came with various length sockets. At the time (2011) I paid $36 I believe. This has been the best spark plug socket I’ve owned in my 18 years of wrenching
Cuervo is offline   Reply With QuoteReply With Quote
Old 03-19-2023, 06:56 PM #10
No problem hand threading the spark plug to start it, the end does not turn independently, I got them hand tight and only needed a small tweak to get to torque.
Old 03-19-2023, 07:02 PM #11
Originally Posted by ArthurKotb View Post
Dictionary
noun: dielectric
Yep,
Yep it went on the tip of the plug that goes in the coil not anywhere near the iridium end. I've done that on every car i've had as some glue themselves to the boots over time. Probably wouldn't happen on the 4R as the plug is held in by the coil screw and there is no detent but it can't hurt. I'm pretty sure the slight misfire I had was one of the spark plugs not being torqued fully, a couple were looser than the others when I removed them.
Old 03-21-2023, 04:19 PM #12
MikeinNH67's Avatar
MikeinNH67's Avatar
Interesting thought as my truck is due for new plugs. If I did Iridium I probably would never need to touch them again and the plugs are only a couple bucks more per plug. Interesting thing is, RA lists different plug numbers for both standard and Iridium between model years 03 & 14. Also different coil part numbers so maybe something is different.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 03-22-2023, 09:03 AM #13
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
I've been running the Denso iridium plugs on my 07 v6, no problems, on a 3rd set now, also with the spark plug socket, I just tape my socket to my extension so it don't come off. I am using this Stanley tool set I got from Walmart since 2008. still works fine, I'll splurge on something better when I win the lotto.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
coils , make , plugs , spark , time
Spark Plug Too Long? Hitting Socket? Issue Cylinder 6 rocky.mtn Maintenance/Detailing 5 10-27-2022 07:04 PM
Spark Plug Too Long? Hitting Socket? Issue Cylinder 6 rocky.mtn 3rd gen T4Rs 3 10-18-2022 07:26 PM
spark plug rounded, remove spark plug tubes? Danger Mouse 3rd gen T4Rs 0 05-02-2021 03:43 PM
Tool Upgrades - Socket and Wrench Sets? Bumbo Maintenance/Detailing 26 04-30-2017 10:39 AM
Spark Socket help? kosan Maintenance/Detailing 2 02-19-2011 08:26 PM
