Old 03-18-2023, 03:07 PM #1
mtnbiker's Avatar
mtnbiker mtnbiker is offline
mtnbiker is on a distinguished road
mtnbiker's Avatar
Question Rear hatch randomly opens
I've searched the forum and have not found an answer to this specific problem. Most answeres I have found is people's hatch won't open, motor problems, locking issues etc.
My hatch motor works. It shuts, it locks. However, I'll be going down the road and every once in a while I'll notice my door ajar light pops on. I have to stop and close the hatch. Sometimes a couple of times within 10 miles, happens more often off-road it seems. Sometimes it will go months without happening.
Will replacing the actuator solve this?
Thanks!
2007 SR5 4WD - Black
Bilstein 6112's Front and 5100's Rear | Spidertrax | Icon Tubular UCA's | Toytec Diff Drop | HCF delete | BFG KO2 265/75/16 | Thule 450, LB58, Flatop 4, (2) Sidearms, T-2 Pro Hitch Mount, Awning | KUAT Skinny Basket | 35% Tint Front Windows | Onboard ARB Twin Compressor | RIGd Supply Ultraswing w/ 2 Rotopax and Frontrunner Table | Firestone Coil Rite Air Bags
mtnbiker is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 03:33 PM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a name known to all xtremewlr is a name known to all xtremewlr is a name known to all xtremewlr is a name known to all xtremewlr is a name known to all xtremewlr is a name known to all
xtremewlr's Avatar
Real Name: Todd
Sounds more like a short or loose wire somewhere, activating the unlatch. Could be the release button that you press when opening the hatch from outside too.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/70/17 Toyo ATIII on Sequoia rims, Sherpa rack, Coastal front bumper, custom rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 08:58 PM #3
mtnbiker's Avatar
mtnbiker's Avatar
Sounds like I just need to get in there and tear it apart. Was hoping for a better solution.
Old 03-18-2023, 10:15 PM #4
Syr4RinNC's Avatar
Syr4RinNC Syr4RinNC is online now
Syr4RinNC's Avatar
Youre able to see and move the latch back and fourth easily? Its not just the motor you hear? IE no sand/ debris getting in the way
It sounds worse than it is to take it apart. Unscrew the rope handle, unsnap the inner panel. Remove the weather strip liner. The actuator has a plastic cover - take it off. Make sure the levers move freely. Try to clean out best you can. Check all the connections
Syr4RinNC is online now   Reply With QuoteReply With Quote
Old 03-20-2023, 04:15 PM #5
MikeinNH67's Avatar
MikeinNH67 is a jewel in the rough MikeinNH67 is a jewel in the rough MikeinNH67 is a jewel in the rough MikeinNH67 is a jewel in the rough
MikeinNH67's Avatar
Clean and lube the mechanism while you still can, that may be all that is needed for now. The hatch has 3 distinct noises, the motor pulling the door in, the latch clicking and then the motor releasing the now latched hatch. Not getting that click seems to always be a latch issue and will allow the hatch to pop open. If you have the door locks set to auto lock then I don't see how it would be a door switch as it should not operate when locked. I have a cheap Amazon latch in my rig right now and it's been working well for a year and a half so far.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 03-22-2023, 11:51 AM #6
T4r.Chris's Avatar
T4r.Chris T4r.Chris is offline
T4r.Chris is on a distinguished road
T4r.Chris's Avatar
I had a problem like this a few years back with mine, only after I had pulled the battery to do radio work/install a backup camera. It happened twice where I’d notice the interior lights come on and would find my hatch was open. Like many others are saying here just pull the hatch apart and ensure everything is clean.
Moisture can get inside the hatch from a bad window seal, so look out for that. The main hatch ECU is on the driver’s side, I think it’s 4 10mm bolts to take it off. Just take a good look at everything.
But spray some good lubricant in the lock mechanisms, pull your battery and let it sit for 15ish minutes before reinstalling. It’ll restart everything.
2005 4Runner SR5 - Build Thread- https://www.toyota-4runner.org/4th-g...ld-thread.html
T4r.Chris is offline   Reply With QuoteReply With Quote
found , hatch , motor , pops , stop
Rear Window Randomly Down During or After Rain schwipt 3rd gen T4Rs 14 04-24-2020 07:41 PM
‘99 Hatch opens.....sometimes aa.allen 3rd gen T4Rs 6 10-07-2017 12:26 PM
MPX B fuse blows when rear hatch opens rlazdowski 3rd gen T4Rs 1 02-24-2014 02:25 PM
4LO light comes on randomly in 2H, rear wiper weird, rear window sticks! Summit Problems & Warranty Issues 5 11-29-2012 07:48 PM
Uhhhhh.. rear window no longer opens with interior switch? ExJeeper 4th Gen T4Rs 12 10-28-2008 12:41 PM
