Old 03-22-2023, 11:14 AM #1
Moist's Avatar
Moist Moist is offline
Moist is on a distinguished road
Moist's Avatar
Weird starting (03 v8)
Every now and again when I start the 4runner, the revs will jump all the way up to 2000 before the engine shakes, it loses power, and dives below 400.
Sometimes it totally stalls out and then refuses to start for a few other attempts. (In that the starter doesn't do anything)
Otherwise it starts just fine. No loss of power driving, and a ticking coming from the engine (most likely serpentine belt).
Not sure what causes this, but it's happening more and more.
Sent from my SM-G973U using Tapatalk
Moist is offline   Reply With QuoteReply With Quote
Old 03-22-2023, 01:01 PM #2
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
My old 91 Camry had symptoms similar to this. Turned out to be the air idle control valve. There seems to be something similar on the V8 4Runner.
Fuel Injection Idle Air Control Valve
You might try taking it off and cleaning it to see if it improves performance. Also check for leaky vacuum hoses.
2003 Toyota 4Runner Fuel Injection Idle Air Control Valve. Bypass - 2227062050 - Genuine Toyota Part
Idle Air Bypass Solenoid - Repair or Replace
Has your 2003 Toyota 4Runner suddenly began idling either too high or too low? This condition is sometimes caused by a faulty idle air bypass valve. Consider having our certified technicians inspect yours to determine the best solution.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 03-22-2023, 01:16 PM #3
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
Originally Posted by Moist View Post
[snip...]
The ticking could be the exhaust header or a tappet. The Gen4s have a known issue with the steel headers rusting and breaking. It's an expensive replacement of the headers. They are steel, not cast iron and cannot be repaired.
My 2004 (137K) has a very slight tick from time to time, especially after a long trip. My son's 2006 (159K) has developed a loud ticking but when the engine gets hot it pretty much goes away. When metal heats it expands and seals the crack... for a while.
Rich
Kentucky
Old 03-22-2023, 03:36 PM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
If I'm not mistaken the IAC valve on 4th Gens is integrated into the throttle body and not a separate part as it was on 3rd Gens and prior models, so you would have to replace the throttle body if it is indeed the IAC causes the issue.
The part/IAC valve at the link posted is for 3rd Gens and some other Toyota models, but not a 4th Gen T4R, click on the "what this fits" link for fitment.
2004 Limited V8
Old 03-22-2023, 05:34 PM #5
Moist's Avatar
Moist's Avatar
Thank you for the response.
Would that valve change idle speed?
If so what would the regular idle be?
I'm idling anywhere from 1200 to 700. (Depends on the day I suppose)
Old 03-22-2023, 06:06 PM #6
Real Name: Skip
Real Name: Skip
Have you tried cleaning or replacing the MAF sensor?
2004 Limited V8
Old 03-22-2023, 07:14 PM #7
Moist's Avatar
Moist's Avatar
No.
Old 03-22-2023, 07:52 PM #8
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Go buy some throttle body cleaner and MAF sensor cleaner and do both and see what happens.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 03-22-2023, 11:06 PM #9
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
Good catch! My bad. It asked me to select a year and it showed a separate part. i didn't notice the caution that it didn't fit. On top of that, there was the text referencing a 2003 and to check with your Toyota shop.
Thanks for catching that!
Rich
Kentucky
Old 03-22-2023, 11:10 PM #10
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
Sincere apologies. I didn't read the text saying it didn't fit the 2003 (gen 4) models. Auseeker says he thinks it's integrated into the throttle body.
Try some throttle body cleaner on it to see if it improves performance. You might also call your dealership or independent garage to get a repair estimate.
Really sorry for the error
Rich
Kentucky
Old 03-25-2023, 01:55 PM #11
Moist's Avatar
Moist's Avatar
Its alright, will pick up some cleaner when I'm free and see what it does.
Thank you all for the help so far!
engine , power , sm-g973u , start , starts
weird issue starting justinsdaddy 3rd gen T4Rs 4 02-23-2015 12:47 AM
Weird starting issue... Maxie 3rd gen T4Rs 18 08-29-2013 12:01 AM
Weird Starting problem NDrun 4th Gen T4Rs 5 04-05-2013 12:46 PM
Weird starting problem Shawn274 General Discussions 5 01-09-2013 10:35 PM
Weird Starting Problem with my 03 Mark86 Problems & Warranty Issues 19 02-11-2007 12:34 PM
