Old 03-25-2023, 07:22 PM #1
RammaR RammaR is offline
RammaR is an unknown quantity at this point
'06 Expansion Valve Replacement
Last year the compressor failed. We replaced it, flushed the system and added a new desiccant bag. It ran fine for several months, but now the a/c system won't cool and the dash light is blinking. Based on the system pressures, we suspect a bad expansion valve
I've pulled the glove box and blower motor, but is it possible to access it without pulling the dash and evaporator? I don't have any reason to suspect the evaporator and would rather leave it be.
I've searched around and haven't found an answer on how to get to the expansion valve. Only time it's mentioned is when doing the evaporator core.
Any suggestions before taking everything apart?
Thanks in advance.
RammaR is offline   Reply With QuoteReply With Quote
Old 03-27-2023, 07:59 PM #2
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Thanks in advance.
Going from memory and the service manual, pretty sure the entire assembly comes out before removing the expansion valve.
That said, if you're replacing the expansion valve you might as well replace the evaporator core at the same time unless you find a hack that gets you enough clearance to remove the air conditioning tubes attached to the expansion valve to free it up.
eleven14 is offline   Reply With QuoteReply With Quote
Old 03-29-2023, 09:50 PM #3
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
Replaced the evap and expansion valve on a '05 last spring. Nothing wrong with the expansion valve- just did it because I had it apart. Used Denso from Rockauto. Don't know of a way to do it without taking it all apart. Agree that you ought to do the evap core also since you're in there.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
Old 03-31-2023, 07:40 PM #4
OSSGuy OSSGuy is offline
OSSGuy is on a distinguished road
I managed to replace my expansion valve by going through the glove box (I also had to take off a couple small pieces of trim). Some of the bolts were almost impossible to get off, and just as hard to get back on. It was really hard to get the servos (that control the air valves) lined up. I sliced my finger on some metal. And I wasn't able to get the white plastic cover that goes over the expansion valve to seat fully (it got a little bent when I pried it off; I couldn't reach the tabs in the back). Pretty sure it was easier than taking the whole dash apart. Definitely faster. But it's a PITA no matter how you do it.
OSSGuy is offline   Reply With QuoteReply With Quote
evaporator , expansion , suspect , system , valve
Where is the a/c expansion valve? Tjmoney 4th Gen T4Rs 5 06-30-2015 12:42 AM
Expansion valve location? Islands 3rd gen T4Rs 8 09-17-2014 03:02 PM
V8 PCV valve replacement schan1w 4th Gen T4Rs 1 02-21-2013 12:45 PM
A/C Expansion Valve Geolander Classic T4Rs 3 07-21-2011 06:09 PM
Expansion valve/evaporator location? Islands 3rd gen T4Rs 0 08-22-2006 12:57 AM
