Shift indicator flickers, cruise control cancels!
So here's a little something I've not seen before.
Once every few weeks I'll be cruising along on the highway and the cruise control is not longer engaged, and the "D" indicator light is flickering as if there is a flaky connection.
When I come to a stop, jiggling the shift between D and 4 or N cleans up the connection and all is well again.
I'm guessing that after 167k miles, that contact in the shift selector is a little gummed up, and there's probably a yes/no circuit passing through that light to determine if the cruise control can be safely activated. (thus disconnecting the cruise control when the shift moves to neutral to prevent the engine from grenading at 12,000 RPM.) My plan is to find this switch, clean up the contacts which are probably covered with goopygoo like the old GM window switches, then be happy for another 160k.
I've taken the shift quadrant apart a few times to investigate the Sticky Shift Syndrome, but have never noticed a shift position sensor in there. To be fair though, I've never really looked for one either.
Any ideas where this might be?
