Old 04-12-2023, 10:36 AM #1
RammaR RammaR is offline
RammaR is an unknown quantity at this point
A/C Light Flashing at Low RPM
The A/C blows cold as long as engine RPMs are above ~1000. However, if it drops to idle, then the A/C clutch disengages and the dash light starts to blink.
I've replaced the A/C relay and tested the low-pressure switch (bypassed it temporarily) and it's the same issue. The operating pressures are good.
My thinking is it may be the speed sensor in or on the compressor itself? Once engine rpm's come back up, I press the A/C button and it comes back to life until the next stop.
Has anyone had a similar issue or know of a way to confirm that before I swap the compressor on a hunch?
Thanks in advance!
RammaR is offline   Reply With QuoteReply With Quote
Old 04-12-2023, 10:51 AM #2
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Your workup looks good to me. I think replacing the compressor is the next step
Old 04-16-2023, 03:12 AM #3
csedman csedman is offline
csedman is on a distinguished road
I replaced the magnetic clutch relay. Solved the problem. Not sure if that's the same relay that you replaced.
Sent from my motorola one 5G UW using Tapatalk
csedman is offline   Reply With QuoteReply With Quote
a/c , back , engine , light , rpms
Well, It started with just ABS Light, VSC Light and A Flashing Multi-Terrain.... EZBR. 5th gen T4Rs 8 01-12-2023 04:54 PM
2008 4Runner, VSC light flashing, traction control and check engine light solid Swelden1 4th Gen T4Rs 6 09-01-2022 09:08 PM
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
Flashing air bag light G_Raw 3rd gen T4Rs 11 02-23-2020 04:28 PM
Check Engine Light and Skid light flashing, truck runs rough tkeratt 5th gen T4Rs 7 07-04-2017 08:44 PM
