Old 03-30-2023, 07:48 AM #1
JailbreakOverlandr JailbreakOverlandr is offline
Real Name: Richie From Boston
JailbreakOverlandr is on a distinguished road
4th gen loses power while driving
Ive had to make some repairs to my 4runner over last month, trucks been on jackstands to pull out dual cases etc. While refilling transmission and jumping out ECU to do so. I noticed several times it lost all power. I concluded it was dead battery from sitting, charged it up all good. trucks back together, I test drib=ve it and while pulling into supermarket parking it lost power Completely. The alarm was freaking out si I pulled fuse on alarm. and she came back to life. But driving home was not awesome waiting for it to die again. Any ideas? Suddenly after sitting and 60K miles it needs an Alternator?
JailbreakOverlandr is offline   Reply With QuoteReply With Quote
Old 03-30-2023, 10:50 AM #2
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
Easy to test the alternator: while the engine is running, the battery voltage should be 14 to 14.5 volts. Most auto parts stores will test the battery for free; they can test for bad cells, capacity, and load.
fkheath is offline   Reply With QuoteReply With Quote
Old 03-30-2023, 11:57 AM #3
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
It sounds to me like a loose connection somewhere, positive wire grounding out, or possibly a bad ground.
When you pulled into the parking lot and it lost power, was there something specific that caused it? For example, turning left(or right), or went over a speed bump? I had the most irritating problem with an old Sentra, replaced the alternator, the battery (which probably all needed to be done anyway), and it turned out that a positive wire running under the battery tray had worn through and was grounding out on the body of the car.
Good luck, let us know what you find.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
alarm , back , lost , power , trucks
Electrical power cutting out while driving sgvT4R 5th gen T4Rs 8 02-16-2024 11:25 PM
While in 4WD HI, occasionally/randomly loses power when trying to accelerate sugjavier 3rd gen T4Rs 1 11-13-2017 02:36 PM
2012 4Runner: Loses all electrical power chasec11 5th gen T4Rs 4 06-18-2013 12:49 AM
Help, engine loses power intermittently neffmoore 3rd gen T4Rs 3 08-27-2010 01:03 PM
Driving with no power steering fluid, is that ok??? Markjr General Discussions 5 09-07-2009 11:20 AM
