Old 04-14-2023, 10:33 AM #1
gookies gookies is offline
gookies is on a distinguished road
OEM Ball Joint - LCA
Has anyone else replaced their LCA ball joint with this OEM one? It seems it's from a Hilux and just checked a local dealership's site, it's available to order. Most of the older threads related to LCA replacement stated you had to replace the entire arm.
Can anyone identify what brand ball joint
Part # 43330-09510
Also, does anyone have a link to the proper tool to remove and re-install the retaining ring? I've ran into a few that might work, but not sure if it'll work on the one installed on the ball joint. Thanks.
gookies is offline   Reply With QuoteReply With Quote
Old 04-14-2023, 12:57 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Just take a screw driver or small punch and hammer and knock the retaining ring off, it comes off pretty easy.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 04-14-2023, 01:02 PM #3
Yeah, I did that recently, the new ball joint (Moog) had a typical retaining clip with the two holes. Just wanted a tool to remove/re-install it easier. Did you do the same when re-installing one of these 'horseshoe' retaining clips?
Old 04-14-2023, 01:35 PM #4
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Reinstall horse shoe ring with pliers, hook one side behind ring other side on far side of BJ and then squeeze it on.
ball , joint , lca , oem , related
Upper Ball Joint/Lower ball joint replacement Tigerfan86 4th Gen T4Rs 1 03-03-2020 03:10 PM
Should I get new ball joint boots, ball joints, or UCA's? Rishi3 4th Gen T4Rs 7 05-25-2017 04:28 PM
Leaking Upper Ball Joint - Replace UCA's or Just the Ball Joint tannerk15 4th Gen T4Rs 4 03-28-2017 08:53 AM
Front Upper Ball Joint - replace arm or joint? dleeallen 4th Gen T4Rs 7 02-05-2016 12:14 AM
Leaking CV Joint or Ball Joint?? Hard to Tell - Pics Inside 4WDFTW 4th Gen T4Rs 21 11-06-2014 05:46 PM
