04-15-2023, 10:39 AM
It was time to add some MORE BEEF!
It was time to upgrade the steering rack for this 4Runner. Tired of breaking little stock tie-rods going over bowling ball sized rocks, so I upgraded! Needed more BEEF because i'm in NO MOOD to be breaking down on trails. It may not seem like much, but the stock steering systems on the 4Runner platform are not made to handle big tires, this is a huge upgrade!
Got a modified Tundra rack installed with new solid piece tie-rods!
04-15-2023, 10:48 AM
Oh very nice! I've been considering this if and when my rack goes out. Did you do the install yourself?
06 V8 SR5 --Kings--JBAs--RCI armor--Lil B's--33s--Wheel and Party--
04-15-2023, 10:52 AM
A buddy of mine mostly did the work, but I did help some. Took about 15 hrs
04-15-2023, 12:38 PM
Woof... so no easy task then
04-15-2023, 03:38 PM
Not quite that easy, It was a super tight fit with getting the rack in, but after that it was smooth sailing, also got new spindles, new uniballs for the lower ball joint, and wheel bearings.
04-15-2023, 05:51 PM
Real Name: Todd
Real Name: Todd
Where'd you get the rack and tierods from?
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
04-16-2023, 08:33 AM
Looks good!
04-17-2023, 10:35 AM
Got the rack from a guy who custom modifies Tundra racks on Instagram by the name of; Basikbiker, and got the custom tie-rods from a a guy on Instagram by the name of; RC_Fabrication
04-17-2023, 01:37 PM
Do you have the V6 or V8? Curious how that rack would fit with the V8. Steering is definitely a weak point in these trucks.
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
04-17-2023, 07:43 PM
I have the V8. I do have after market motor mounts that help set the engine up a smidge. Fitting the rack was tight! I have about a quarter inch of clearance from the rack to the oil pan.
04-17-2023, 10:59 PM
Impressive!
04-18-2023, 12:23 AM
Awesome. How does the steering feel now?
04-18-2023, 12:28 AM
Feels like a new vehicle and more solid. I have aluminum bushings instead of rubber, so there is no slop or play in this rack unlike the stock rack.
04-18-2023, 12:14 PM
Did Basikbikers aluminum offset bushings bolt right up to your factory mounting holes? How much engine lift do you think would be necessary to make the Tundra rack fit? Sorry for all the questions lol
04-18-2023, 02:38 PM
Oh one other question, have you noticed your turning radius is worse now? I believe I read somewhere that it is but just confirming.
