Old 04-18-2023, 03:21 PM #16
awhitney1 awhitney1 is offline
awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about
I haven't really noticed much of a difference!
Originally Posted by thegame7 View Post
Oh one other question, have you noticed your turning radius is worse now? I believe I read somewhere that it is but just confirming.
awhitney1 is offline   Reply With QuoteReply With Quote
Old 04-18-2023, 03:23 PM #17
The offset bushings did mount up to the factory mounting holes which was nice! I'm not sure how much of a life of the engine is needed or necessary. Probably helps that I have after market motor mounts and they don't make the engine sag lower than the stock ones. Happy to answer any questions!
Did Basikbikers aluminum offset bushings bolt right up to your factory mounting holes? How much engine lift do you think would be necessary to make the Tundra rack fit? Sorry for all the questions lol
Old 04-18-2023, 05:47 PM #18
thegame7 thegame7 is offline
thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice
Thanks for the info! All good stuff for sure. Who did you get the tie rod kit from?
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
thegame7 is offline   Reply With QuoteReply With Quote
Old 04-18-2023, 05:48 PM #19
From a guy on Instagram who goes by; RC_Fabrication
Old 07-12-2023, 12:52 AM #20
I do have one other question, did you need to do anything custom to get the power steering lines to bolt up to the Tundra rack?
Old 07-13-2023, 08:24 AM #21
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
really wishing I went this route from the get go over the LC 200 rack..
I also see you're running the clevis setup on yours, wondering what your bump steer looks like between full bump and full droop. The lc200 on factory width control arms definitely pigeon-toes the tires way in at full droop, not to mention my messed up Ackermann angle from it sitting a little further back from the factory setup. I'm definitely scrubbing the outside tire across the ground as I get near full lock.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 07-13-2023, 09:11 AM #22
I really haven't noticed any difference at full droop and full bump, then again, I haven't really tested it that much.
Old 07-13-2023, 02:42 PM #23
Did you have to do anything custom to get the high pressure power steering lines to work?
Old 07-16-2023, 11:33 AM #24
meltdowner meltdowner is offline
Real Name: Tim
meltdowner is on a distinguished road
Real Name: Tim
Beautiful
meltdowner is offline   Reply With QuoteReply With Quote
Old 07-17-2023, 02:04 PM #25
No custom work needed, all steering lines bolted up just fine on the new rack.
Old 07-17-2023, 04:29 PM #26
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Yea the bump steer is pretty bad w the 200. I tried everything I could think of to make it tolerable, but no dice. So far my 4 year old CVJ is holding up.
Sorry I put that 200 idea in your head.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 07-17-2023, 04:32 PM #27
Real Name: Brett
Real Name: Brett
Glad you got it installed w no issues. I bought a used one, some day I'll get it modded and put in there.
Old 07-18-2023, 09:16 AM #28
Wow that's pretty awesome actually. Wonder what basikbiker is charging for Tundra racks now.
Old 07-18-2023, 11:06 AM #29
I bought mine last fall for $1400. That may or may not have changed.
4runner , breaking , rack , stock , tie-rods
is there anyway to beef up the 3.4? 99NWA4R 3rd gen T4Rs 26 08-17-2018 12:22 AM
RCI Alu Trans Skid beef up wfo9 5th gen T4Rs 3 11-15-2017 01:05 PM
Got yet another beef with Toyota..Clips! knightsfs4 4th Gen T4Rs 18 09-24-2012 07:44 PM
I want to beef it up w/o going broke Ernest1863 4th Gen T4Rs 7 08-03-2012 09:24 PM
