Old 04-23-2023, 10:26 PM #16
Az4runnin's Avatar
Az4runnin Az4runnin is offline
Az4runnin will become famous soon enough Az4runnin will become famous soon enough
Az4runnin's Avatar
Thumbs down
Ac clutch is engaging without jumping but Freon is still not being taken into the system. Can of freon should get cold as it's going into the system and it's just not happening.
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is offline   Reply With QuoteReply With Quote
Old 04-26-2023, 10:24 AM #17
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
its likely a mechanical issue then...check the valve on the can that its dispensing and the valve on the car that it can accept inflow.
u can do this by depressing the thin stem inner core of the valves
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 04-26-2023, 12:10 PM #18
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
I haven't done any A/C work on my 04 T4R but I've done it on a '91 Camry I had until a few years ago. That had a pressure switch that wouldn't engage the compressor if the R134 was too low. If you kept it connected, eventually the compressor would kick in and it would take the refrigerant.
I had problems with the attachment not connecting well to the low pressure port. I had to hold it tight against the connection and eventually it would start drawing it in. It was just a cheap device but it got the job done once I figured out the issue. Try pushing the connector tight against the connection on the low side port.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 04-26-2023, 03:40 PM #19
Az4runnin's Avatar
Az4runnin's Avatar
I will also add that the low pressure Schrader valve was replaced a few years back when I had a shop recharge the system.
freon , low , pressure , side , switch
4th Gen Freon Capacity JMZ400 4th Gen T4Rs 8 07-21-2018 07:50 PM
A/C Freon jvalasky Classic T4Rs 3 05-09-2013 01:31 AM
Recharging A/C with freon Rictavian Maintenance/Detailing 2 04-10-2011 09:05 PM
Freon booster kits? mnormand Maintenance/Detailing 3 06-16-2010 09:19 PM
Where to check freon level in a 86 4runner Nomad2day Classic T4Rs 1 05-07-2006 08:46 PM
