Old 04-24-2023, 03:01 AM #1
d33pt d33pt is offline
d33pt is on a distinguished road
What tire pressure do you run?
I'm running 255-85/16 BFG Mud Terrain Load Range C. I'm running 30 psi, but I still feel like that's too much. It seems to be wearing more in the middle. What do you guys run?
d33pt is offline   Reply With QuoteReply With Quote
Old 04-24-2023, 10:15 AM #2
LOSTR4's Avatar
LOSTR4 LOSTR4 is offline
LOSTR4 will become famous soon enough LOSTR4 will become famous soon enough
LOSTR4's Avatar
Sheesh, that seems fine, but on the low side in "C." I run lowest on my "E's" 40psi in winter...usually 45 through the warmer months...Isn't the recommended PSI rating like 35psi for these? Do you have photos of the potential wear? Are you sure your gauge is accurate? Silly questions I know but something isn't adding up in my head...
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
LOSTR4 is offline   Reply With QuoteReply With Quote
Old 04-24-2023, 10:24 AM #3
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
If you're wearing out in the middle of the tread you are over inflated. Wearing out on the sides and you are under inflated. I don't go off road but i do tow a 23' Airstream travel trailer. When pulling the trailer I have 35 PSI and when not I have 32 PSI, which is what is listed in the driver's door for proper inflation.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 04-26-2023, 08:38 AM #4
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
32 psi
<<<< is offline   Reply With QuoteReply With Quote
Old 04-27-2023, 03:52 PM #5
stevelikesrhino stevelikesrhino is offline
stevelikesrhino is on a distinguished road
If you have ultra large tires (285 and above), wearing the center indeed means overinflation, but you have 255. It's very likely the combination of KM3 tread design and, drive wheels tends to wear in center (steer wheels tends to wear on shoulders). Don't worry about it, just rotate often, or drive in 4hi more.
stevelikesrhino is offline   Reply With QuoteReply With Quote
Old 05-04-2023, 11:33 AM #6
bakeajoe bakeajoe is offline
bakeajoe is on a distinguished road
In my extensive search to find what tire pressures to run I ended up just running what feels fine and stop worrying about it. I have Load E 295/75/16 and the local tire shop recommended running them at 35. Many people will say that they need to hold much more and when I ran them at 48 they definitely saved maybe 1mpg and you can feel them having less resistance on the road but I was worried about them not wearing right. They also felt like they grabbed ruts in the road a little more which was not good considering I have to commute downtown. I did a chalk test at 35 psi and found that the outer edges weren't contacting the ground as much but found out that when you make turns you actually wear down the outer edges just a tad so it's normal to see the outer edges just slightly lower. In summary just run whatever your tire shop recommends or whatever the experts say and just leave it. I would be more focused on checking them and making sure that they are always at a specified number.
bakeajoe is offline   Reply With QuoteReply With Quote
Old 05-05-2023, 12:38 PM #7
Moist's Avatar
Moist Moist is offline
Moist is on a distinguished road
Moist's Avatar
I run 45 PSI on wider TOYO open country A/T tires. Works great for me, handles like a champ.
Sent from my SM-G973U using Tapatalk
Moist is offline   Reply With QuoteReply With Quote
Old 05-05-2023, 06:21 PM #8
Kevin G. Kevin G. is offline
Kevin G. is on a distinguished road
Lightbulb Tire pressure.....
For my 2008 T4R V8 Sport 2WD.........35# front......32# rear.
Even wear all around........through 3 sets of factory sized Michelin LTX-MS tires.
Hope this helps.
Kevin
Kevin G. is offline   Reply With QuoteReply With Quote
Old 05-09-2023, 08:50 AM #9
Flyer Flyer is offline
Flyer will become famous soon enough
The best way (especially if running C and D rated tires) is to do a chalk test. Google this...offroadewrs do this a lot since they run larger and often higher-rated tires. Most others run way too high PSI. With Cs on the lighter-than-most Rubicon, the chalk test showed that I should be at 28 PSI. That wore evenly. On the 4Runner and P rated ATs, I run 33 front and 32 rear now. If I ran Cs, I'd prob be around 28 but I have not run Cs so I don't know for sure. Also some tires have stiffer sidewalls like the KO2s while DuraTracs have thinner sidewalls that flex more at the same PSI.
2005 V8 4Runner 4X4 SR5, FJ TRD Bilstein Suspension, KO2s
2020 Mercedes GLE450
2014 Wrangler Rubicon, Synergy suspension + 35 MTRs + way too many mods
Flyer is offline   Reply With QuoteReply With Quote
Old 05-09-2023, 10:15 AM #10
Ripper238's Avatar
Ripper238's Avatar
I run at 38-40 psi, so you should too.
Sounds like its just a trait of running a mud tire of that type on road. Likely rotate often will help. You can certainly lower the PSI but at some point it may be too low for the weight of the vehicle.
Old 05-12-2023, 11:02 AM #11
Rice400 Rice400 is offline
Rice400 is on a distinguished road
35psi usually
Rice400 is offline   Reply With QuoteReply With Quote
Old 05-19-2023, 09:33 AM #12
PA Old Guy PA Old Guy is offline
PA Old Guy is on a distinguished road
32 psi as listed on the door. I can run hundreds of miles (short trips) with no tire sensor light coming on. If I do close to 30 miles I get a blinking tire warning light. When scanned, it gives codes communication was lost with either 2 or 3 monitors. Would a change in tire pressure help. Why does it come on at about the 30 mile mark?
PA Old Guy is offline   Reply With QuoteReply With Quote
Old 05-19-2023, 09:37 AM #13
32 is ideal. You may need to replace your TPMS valves. Mine started to die in 2021. Apparently they will last around 10 years (the Toyota ones anyway) but I got over 15. I got new OEM ones and no issues since. I did have issues with the generic ones.
Old 05-19-2023, 10:21 AM #14
Thanks for the info, I was leaning that way. I am just curious why I can drive months short distances without losing communication and then the longer ride results in the codes. Could heat have something to do with it?
After clearing codes I am good until I drive a distance.
Old 05-19-2023, 10:44 AM #15
if the sensors are very old, they will do weird things and get progressively worse. I think new ones are easy to get from Toyota. I generally will not use aftermarket parts when it comes to sensors, filters, and electronic stuff. This may be my last Toyota so I'm trying to make it last.
feel , middle , run , running , wearing
Low tire pressure, but highlighting the wrong tire? 2021nightshade4x4 5th gen T4Rs 7 10-19-2022 05:16 PM
What's causing this tire wear pattern? Alignment or tire pressure? TheHolyCannoli 5th gen T4Rs 13 12-01-2020 04:10 PM
low tire pressure light ...for the spare tire?????? soimcrazy 4th Gen T4Rs 33 12-25-2018 04:23 PM
Tire Pressure Sensor - Spare tire Tdub 4th Gen T4Rs 3 09-01-2008 10:49 AM
Tire Pressure & Max Rated Tire Pressure Phil 4th Gen T4Rs 7 03-10-2004 10:49 PM
