Old 04-24-2023, 12:10 PM #1
Bahnstoermer's Avatar
Bahnstoermer Bahnstoermer is offline
Bahnstoermer is an unknown quantity at this point
4.7L Battery Light On, Burning Smell...
I started the 4.7L in my 2008 4Runner, heard a whine, after a short drive the battery light came on. Blue Driver showed no codes. Drove it home, and have a burning smell / light smoke upon opening the hood...I couldn't investigate more at the moment, had to switch cars and go.
I'm at the very beginning of getting my bearings on possible issues...
Locked-up alternator? Common failures with these symptoms?
2008 4Runner: 4.7L V8 - AWD with Torsen/Lockable Center Diff
Upgrades: Icon Stage I - SpiderTrax 1.25 - WeatherTech - BFG AT T/A KO LT265/70R17/C
Bahnstoermer is offline   Reply With QuoteReply With Quote
Old 04-24-2023, 01:21 PM #2
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Sounds like the alternator pulley seized and your belt is burning because of it.
Rich
2004 V8 4Runner 138K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 04-24-2023, 05:52 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I had my serpentine belt tensioner pulley bearing seize up on my V8 which squealed loudly and smell like burning rubber until the serpentine belt broke at which time the battery light came on, with many vehicles when the serpentine belt breaks it will also overheat because the belt also turns the water pump, but on these V8s the timing belt turns the water pump, so I could still drive until my battery died from not being charged, replaced the tensioner pulley bearing and installed a new serpentine belt and all was fine.
That being said you could have the same issue as I did if your serpentine belt is broken, or it could also be the serpentine belt idler pulley or both pulleys.
It could be as mentioned if the belt is still some what intact be the alternator seized up instead, but usually an alternator doesn't seize up they usually just quit working unless they have rusted inside.
2004 Limited V8
4.7l , battery , burning , light , smell
Burning smell Jaketino 3rd gen T4Rs 8 07-11-2014 05:33 PM
Burning Smell Anyone? afx604 4th Gen T4Rs 18 04-10-2014 07:52 PM
Burning rubber smell after 'hot brake' smell westwind77 5th gen T4Rs 7 02-11-2013 01:26 PM
Light burning smell from under hood (driver's side) IdahoAngler 3rd gen T4Rs 8 03-01-2012 10:17 PM
Burning grease / Burning rubber smell? Cape 4RUNNER 4th Gen T4Rs 3 01-04-2010 12:39 AM
