04-28-2023, 07:19 PM
Alternator voltage with engine running
Troubleshooting a potentially bad alternator - 2007 V6 @ 163k. Believe it’s the original alt. Tested voltage at the alternator lead with truck running, and got about 0.03v. Even if the alt bad, shouldn’t this still read around 12.6v? Makes me wonder if there’s a bad connection b/t alt and battery.
Batt voltage w/ engine running was 12.5v. I know that means it’s getting nothing from alt.
140a fuse looks ok. Is there another fuse for it?
Checked ohms from batt to alt and got 0. Any other test I could do to rule out wiring?
Thanks to anyone who could chime in!
Reason: More info
04-28-2023, 07:29 PM
did you check the alt-s fuse? that is the charging fuse i think.
also your brush might be worned.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
04-28-2023, 07:34 PM
I checked the 140a in the fuse box, is this a different one? If so, where is it located?
04-28-2023, 07:38 PM
its in the fuse box also, its the smaller ones. your fuse box cover will show
7.5amp
04-28-2023, 08:54 PM
7.5amp
Thank you kindly, I’ll check it out
04-29-2023, 05:52 AM
Originally Posted by Toystory2
Checked ohms from batt to alt and got 0. Any other test I could do to rule out wiring?!
Resistance is not the correct test - you need to look at voltage drop.
https://www.youtube.com/watch?v=EMS8On17BnM
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
04-29-2023, 10:51 AM
Originally Posted by Buckaroo
Thanks for the tip. Just ran this test and got between 0.02 -0.09 on the positive circuit. Got 0.0 on the negative circuit. So looks like there’s not much drop at all.
04-29-2023, 07:55 PM
So wiring looks good. If you are going to replace it, I suggest Denso Reman from RockAuto....
2004 Honda Accord
04-30-2023, 10:14 PM
Thanks, I got a Toyota reman from EBay, which I believe is Denso anyway.
04-30-2023, 10:36 PM
did you consider doing a high output alternator?
any large electrical add ons?
im using the mechman 240a, its pretty good for my needs
05-01-2023, 01:53 PM
I don’t have any add-ons, but you bring up a good point. Now would be the perfect time to upgrade if I was going to.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
