Old 05-08-2023, 02:14 AM #16
JaySavin888 JaySavin888 is offline
Real Name: Jason S.
JaySavin888 is on a distinguished road
Real Name: Jason S.
Gotta say i love how toyota designs their vehicles to still look fine even after years have passed nice truck man
JaySavin888 is offline   Reply With QuoteReply With Quote
Old 05-08-2023, 02:17 AM #17
Real Name: Jason S.
Real Name: Jason S.
I wish toyota didnt stop making these in V8
Old 05-08-2023, 09:55 AM #18
apv97 apv97 is offline
apv97 is on a distinguished road
Originally Posted by Jakeepoo3 View Post
If you want to maintain your factory ride quality and height with no load on the rear and be able to tow a load with no sagging you would need variable rate coils. I don't recommend airbags.
Why do you not recommend airbags?
apv97 is offline   Reply With QuoteReply With Quote
Old 05-08-2023, 04:39 PM #19
MikeinNH67's Avatar
MikeinNH67 is just really nice MikeinNH67 is just really nice MikeinNH67 is just really nice MikeinNH67 is just really nice
MikeinNH67's Avatar
Except for the leather seats.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 05-14-2023, 10:52 AM #20
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Originally Posted by apv97 View Post
ArthurKotb - not using an aftermarket WDH. But mine has the beefier hitch rated for 7000 lbs. She tows pretty well! My concern is more for the trailer tires wearing poorly and the hitch dragged on inclines with the tongue being too low. Don't think my XREAS is leaking as I haven't noticed anything "wrong" with the suspension.
GBagwell - Not sure on my tongue weight, but the loaded boat + trailer weighed in at 6000 lbs on a truck scale last fall.
Your receiver, if you have the tow package with the frame hitch, is rated to pull the 7,000 lb. (4X4) capacity and the vehicle can support 700 lbs. of weight on the hitch, including the hitch weight. A standard hitch in the receiver supports all of that weight on the rear of the T4R. A WDH, like the Equalizer, shifts some of the weight on the front axle and some is moved onto the trailer's axle(s).
If your rear is sagging and you are using a standard hitch in the receiver then a WDH will improve that and your handling as well. When you put weight on the hitch you're lifting the front tires up. The T4R compensates for that by shifting more braking to the rear wheels. A WDH will shift the weight to the front and trailer axles. Air bags won't do anything to improve your control. The weight is still there on the rear. The air bags just put pressure on your suspension to lift up the body and make it look better; it isn't.
Find an Equalizer (or other) WDH installer and talk to them about your rig.
Rich
2004 V8 4Runner 138K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 05-14-2023, 11:07 AM #21
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
Everything is going turbo. I was looking at the new 2023 Sequoias because you can't get the T4R in V8, figuring I'd have to move up if I needed a new tow vehicle. Here's the new 2023 Sequoia:
Turbocharged 3.4-liter V6 hybrid powertrain
437 horsepower
538 lb-ft of torque
10-speed automatic transmission
21 mpg city, 24 mpg highway and 22 mpg combined (2WD)
19 mpg city, 22 mpg highway and 20 mpg combined (4WD)
Towing:
Limited Towing Capacity (2WD/4WD): 9,300 pounds/9,020 pounds.
Platinum Towing Capacity (2WD/4WD): 9,310 pounds/9,010 pounds.
TRD Pro Towing Capacity (4WD): 9,020 pound
Price is around $59K, if you can find one.
Rich
Kentucky
Old 06-25-2023, 07:45 PM #22
Installed the Airlift 1000 kit a couple weeks ago. So far so good. Installation wasn't bad and hasn't lost any significant amount of air yet. I had it around 12psi (min=5, max=35) for towing my 6000lb boat trailer. Previously it was 15" off the ground unweighted and 12" weighted. With the kit at 12psi it was about 15.5 unweighted and 14.5 weighted. So took out about 2.5" of sag, which should help a lot with trailer tire / bearing wear and tear on the front axle of my tandem trailer!
airbag , kit , rear , springs , towing
4th Gen Sport Edition Suspension Parts - SoCal BOFFROAD Free 9 04-30-2017 02:33 AM
Question about adding rear airbag suspension kit GLP 4th Gen T4Rs 16 04-02-2016 10:39 PM
Adding Horns to 2005 4Runner Sport Edition Ryker 4th Gen T4Rs 32 04-21-2014 11:18 PM
99-00 4r highlander suspension on an 01-02 sport edition? TC2002SE 3rd gen T4Rs 0 02-07-2014 02:11 AM
Rear Suspension (OME vs Toytec vs Airbag) LEO98 Engines / Suspension / Wheels / Tires / Audio / Accessories 13 09-13-2011 05:52 PM
