Old 04-30-2023, 10:16 PM #1
apv97 apv97 is offline
apv97 is on a distinguished road
Adding rear airbag suspension for towing? (V8 Sport edition)
My 2004 V8 Sport edition does pretty well with towing my 6000 lb boat+trailer, but the 19 year old springs and substantial tongue weight are making the rear sag significantly.
I don't really want to lift my 4runner (I don't off road), but want to ensure it's level while towing for best performance and avoiding trailer tire wear.
My friend suggested an airbag kit like this:
1998-2023 Toyota 4Runner - Firestone Coil-Rite Air Bag Helper Springs (NO-DRILL) [REAR] [4135] | $121.15 | SD Truck Springs | Leaf Springs, Helper Springs and Suspension Parts
Has anyone done something like this? Would you recommend it or should I look at stiffer replacement springs / lift kit? Would like to keep to <1k if possible but honestly pretty clueless when it comes to suspension work.
apv97 is offline   Reply With QuoteReply With Quote
Old 04-30-2023, 11:49 PM #2
d33pt d33pt is offline
d33pt is on a distinguished road
Try Timbren SES first. Cheaper and way easier to install.
d33pt is offline   Reply With QuoteReply With Quote
Old 05-01-2023, 12:51 AM #3
Gamblin4Runner's Avatar
Gamblin4Runner Gamblin4Runner is offline
Gamblin4Runner is on a distinguished road
Old Man Emu
Old Man Emu Suspension (07-09 FJ & 03-09 4Runner) - OME-FJ4R
Front Shocks:
2 x 90021 - Old Man Emu Nitrocharger Sport Front Shock - Softer Valving - Single
Trim Packer:
1 x OME95PF5 - OME Trim Packer
Front Coils:
1 x OME-885 - Old Man Emu Front Coils
Assembly with new top mounts and bushings/washers:
1 x TMP-05 - Top Mount Kit (includes assembly)
Front diff drop kit:
1 x RM83011 / TAC-DR-05 - Toytec Front Differential Drop Kit - 05+Tacoma, 03+4Runner, 07-14 FJ Cruiser, 03+GX
Rear Coils:
1 x OME-895E - Old Man Emu Rear Springs
Rear Shocks:
2 x 60004 - Old Man Emu Nitrocharger Sport Rear Shock (07-09 FJ, 03-09 4Runner, 03-09 GX470) - Single
Add rear shock stone guards:
1 x OME661 - OME Rear Shock Stone Guards
$1282.37 in the cart - setup I'm running and it has served me very well! Good Luck!
'06 4Runner Sport Edition V8 4x4 | Thorley LT Headers & Y-Pipe | Gibson Elite Exhaust | YotaWerx ACTIVE DUTY Tune | 33" Kenda Klever R/T KR601's | 17" TRD Gloss Gunmetal Gray Wheels | OME Lift Kit w/ Diff Drop | Smittybuilt XRC 9500# w/ BudBuilt hidden mount | Cali Raised LED Ditch Lights | Victory Skid Plates | Sony XAV-AX6000 w/ factory JBL's | Hydrocarbon Filter Delete | Complete LED Conversion - Interior & Exterior
Gamblin4Runner is offline   Reply With QuoteReply With Quote
Old 05-01-2023, 09:27 AM #4
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
mine was sagging pretty bad with the old suspension, upgraded to ome/bilstein combo and went ahead and installed the airbags as well. rides and tows extremely well with the airbags compared to how it was previously. install is super easy.
daprotege5 is offline   Reply With QuoteReply With Quote
Old 05-01-2023, 04:50 PM #5
MikeinNH67's Avatar
MikeinNH67's Avatar
I put Timbrens on the front of a truck I installed a plow on. Kept the front up but made the ride harsh. I've used Airlift 1000's on a van in the past for towing a camper. Love the adjustability and ride they gave.
2004 Toyota 4runner 4 WHEEL DRIVE Air Bag Suspension Kits | Air Lift Company
Amazon.com
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 05-03-2023, 12:18 AM #6
GBagwell's Avatar
GBagwell GBagwell is offline
GBagwell will become famous soon enough GBagwell will become famous soon enough
GBagwell's Avatar
I agree with Mike. Prior to lifting my 03 limited V8 I added the airlift 1000’s Same as the link provided. I could air them down for a comfortable ride, and then air them up just a bit to level things out when I was towing my Casita RV.
Things to know. You have to cut down the original bump stop, and I had to enlarge a hole in the center or the spring seat for the air line to run through comfortably. I’ve run this setup for probably 12 years. A couple years ago I switched to Firestone air bags as there was a longer version I needed when I added a Dobinsons lift and had a longer spring in the back. Image is of the Firestone bag.
Adding rear airbag suspension for towing? (V8 Sport edition)-0b421cb6-548c-42f6-94ef-40b322341f85-jpg  Adding rear airbag suspension for towing? (V8 Sport edition)-320103e4-c071-4ae9-a79f-fa6e37073dca-jpg
86 4Runner, 91 4Runner, 97 4Runner Limited, 2003 4Runner V8 4x4 Limited (current ride - Original Owner)
GBagwell is offline   Reply With QuoteReply With Quote
Old 05-03-2023, 05:52 PM #7
Thanks all. Sounds like airbags are a viable way to go.
Timbren SES (bump stops) seem similar in price to air bags and a less versatile more bandaid solution. Think I can handle the slightly harder install of the airbags!
Gamblin4Runner — your setup sounds great! But want to avoid an entire suspension overhaul if possible.
daprotege5 — which Bilsteins are you running?
GBagwell — good info on installation. Did you replace / upgrade your springs or shocks, or strictly an Airbag addition? Trying to determine if I need to replace/upgrade the springs and shocks or if Airbags alone will work.
Old 05-04-2023, 09:19 AM #8
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
if you want to do it even cheaper, you can stuff a football and air it up. but the firestone airbags are a good choice when it comes to installation. if your suspension is old and worn, consider new springs and shocks. and go from there.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 05-04-2023, 12:56 PM #9
Sounds like a plan. Is there anything I need to know about XREAS for this? I think my car would have it since it's a Sport edition but I know nothing about what this means re: effect on suspension jobs.
Old 05-04-2023, 02:12 PM #10
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Do you use a weight distribution hitch? I pull a 6,000 lb. Airstream with my 04 T4R V8 and it's pretty level, even with 730 lbs. on the hitch. I use an Equalizer hitch and once it get it dialed in correctly it's fairly easy to hook up and go. My opinion is that air bags will make your T4R level but it's not adding anything to support the additional weight. A WDH moves some of the weight off the rear axle and put it on the front and trailer axle(s).
Another nice think about a WDH is you don't have to modify the vehicle at all. You just make adjustments to the hitch. When you're finished towing you just remove the hitch.
I have a Sports Edition also. The X-REAS shocks were standard on the SE. I've never had a problem with mine and the T4R tows the Airstream very well. Cornering, turns, lane changes, high winds, it takes it all in stride. I purposely bought the SE because of the X-REAS for their handling capability. If they aren't leaking then they should be fine.
Adding rear airbag suspension for towing? (V8 Sport edition)-dscn1652-jpg
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 05-05-2023, 03:10 AM #11
GBagwell's Avatar
GBagwell's Avatar
One of the things to consider is that my 03 limited V8 is a 4wd and has a 5000 pound tow limit, and a 500 tongue weight limit. The hitch connection to the frame is different than on some of the 2wds from back in the day. The 2nd had I think 7000 pound limit and a more substantial hitch,
I didn’t feel the weight distribution hitch was the right way to go for me, also considering some of the dirt roads I travel and wanting a bit more flexibility at the hitch connection. And my trailer fully loaded is less that 4000 and less than 300 tongue weight on the hitch.
Just an FYI on what I run.
Old 05-05-2023, 08:28 AM #12
bilstein 5100 w/ ome springs w/ the airlift 1000
Old 05-05-2023, 09:14 AM #13
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
The '03 models didn't have the frame hitch like later model Gen 4s. I was going to buy an '03 and something came up that diverted funds elsewhere, so I ended up with the '04 and a better hitch. However, hitches can be upgraded.
My '04 4X4 has a 7,000/700 towing capacity. The 4X2 is slightly higher. I know of a company in Canada that is well known to Airstreamers, Can-Am RV. One of the people in the group had his V6 Sienna modified to tow a 28' model. (mine is 23')
Towing Expertise | Introduction - Airstreams | Campers London | Travel Trailers for sale
The Toads of Towed Haul
Towed Haul
He doesn't maintain his sites anymore. He had the story "You can't tow that with this" posted but I can't find it now. Can-Am RV has a lot of Airstreamer business; good company.
Rich
Kentucky
Old 05-07-2023, 11:30 PM #14
ArthurKotb - not using an aftermarket WDH. But mine has the beefier hitch rated for 7000 lbs. She tows pretty well! My concern is more for the trailer tires wearing poorly and the hitch dragged on inclines with the tongue being too low. Don't think my XREAS is leaking as I haven't noticed anything "wrong" with the suspension.
GBagwell - Not sure on my tongue weight, but the loaded boat + trailer weighed in at 6000 lbs on a truck scale last fall.
Old 05-08-2023, 01:12 AM #15
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
If you want to maintain your factory ride quality and height with no load on the rear and be able to tow a load with no sagging you would need variable rate coils. I don't recommend airbags.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
airbag , kit , rear , springs , towing
4th Gen Sport Edition Suspension Parts - SoCal BOFFROAD Free 9 04-30-2017 02:33 AM
Question about adding rear airbag suspension kit GLP 4th Gen T4Rs 16 04-02-2016 10:39 PM
Adding Horns to 2005 4Runner Sport Edition Ryker 4th Gen T4Rs 32 04-21-2014 11:18 PM
99-00 4r highlander suspension on an 01-02 sport edition? TC2002SE 3rd gen T4Rs 0 02-07-2014 02:11 AM
Rear Suspension (OME vs Toytec vs Airbag) LEO98 Engines / Suspension / Wheels / Tires / Audio / Accessories 13 09-13-2011 05:52 PM
