Old 05-03-2023, 04:04 PM #1
knightsfs4's Avatar
knightsfs4 knightsfs4 is offline
knightsfs4 is an unknown quantity at this point
knightsfs4's Avatar
Front Speaker Sound Is LOW - Diagnostic Thread
I've had my 2006 4Runner for almost 15 years now, and two years ago I had my entire sound system replaced. Front / Rear speakers replaced with JBL aftermarket speakers, JL Audio AMP, Pioneer Head Unit.
As the title states, the front right speaker is very low for some reason now.
Here is some back story. Everything was fine until one day the speaker went out. As I was driving at times, if I would hit a bump it would come back on for a bit, then go out if I hit another bump.
I took off the door panel, and it doesnt look like any wires are loose. I replaced the speaker with a new one and it still sounds very low, same as the old one. Wires on the back of the amp seem tight. Haven't gone to check the wiring on the head unit.
Would appreciate some insight on this if anyone else has faced a similar issue.
Thank you!
Knightsfs4 Build Thread http://www.toyota-4runner.org/4th-ge...ld-thread.html
Jack-Purchased on 11/22/10- 2006 Limited 4X4 V8
knightsfs4 is offline   Reply With QuoteReply With Quote
Old 05-03-2023, 05:38 PM #2
Ph03n1x24's Avatar
Ph03n1x24 Ph03n1x24 is offline
Real Name: Mark
Ph03n1x24 is on a distinguished road
Ph03n1x24's Avatar
Real Name: Mark
Definitely sounds like something is shorting out.
The wires you're looking for are:
(Coming out of the head unit *high side*)
Right front: + GRAY
Right front: - GRAY/BLACK
Did you cut into the wiring harness or use an aftermarket connector like this?
Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker
Amazon.com
If the speaker and connections there check out fine as well as to the amp then it's most likely a bad connection coming out of the head unit. I'd pull the harness where it connects to the back of the hu if it's a "quick disconnect" and make sure no pins have backed out of the connector. Then make sure it seats solidly back to the hu. I'd also check the 10 pin connector (if applicable) where it connects to your vehicles stereo wiring harness and check for any pins backed out. Other than that, if you used butt connectors that would be the most likely culprit.
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics | Retrofit LED / USB 3.0 | PC38 Pedal Commander | Alpine iLX-w650 w KTA450 | Kicker KS Series 6"x9" 3-way - CS Series 3/4" dome tweeters - KS Series 6-1/2" 2-way | Hifonics BXX1200.1D 1200W RMS 1 Ohm amp | Dual JL 10w6v2's |Q box 50hz
2011 Toyota 4Runner SR5 - Soundproofing | HU & Speaker Upgrades
Ph03n1x24 is offline   Reply With QuoteReply With Quote
back , front , low , replaced , speaker
98' 4Runner 2.7 STD idle sound, Normal or Diagnostic? Oregon-Runner Max 3rd gen T4Rs 6 03-20-2014 11:27 PM
98' 4Runner 2.7 STD idle sound, Normal or Diagnostic? Oregon-Runner Max Maintenance/Detailing 0 03-20-2014 05:29 PM
No sound after speaker upgrade parawing742 4th Gen T4Rs 9 03-10-2014 11:14 AM
Sound Quality of 8 speaker Entune system vs. 15 Speaker Nav/JBL system Crit Rat 5th gen T4Rs 5 01-17-2012 06:39 PM
JBL 10 Speaker Sound marnok Engines / Suspension / Wheels / Tires / Audio / Accessories 0 06-20-2006 10:05 AM
