Old 05-09-2023, 04:56 PM #1
Ph03n1x24's Avatar
Ph03n1x24 Ph03n1x24 is offline
Real Name: Mark
Ph03n1x24 is on a distinguished road
Ph03n1x24's Avatar
Real Name: Mark
Stubborn P0304, P0306 Misfire on Cyl 6
2005 Toyota 4runner Sport Truck V6 ~245,XXX miles
CEL P0304
Tejas Toyota Dealership in 2018 @ ~119,XXX miles
- Replaced plugs
- Replaced coil on cyl 6
<<< Problem solved >>>
Fast forward to today: 2023 ~245,XXX miles
CEL: P0304
- Replaced all spark plugs w/ NGK 6619 Iridium Spark Plugs
- Replaced all 6 coils
Ran great for a week or two then the P0304 code came back.
- Went back and retorqued the spark plugs to 13 lbs.
After a few days it's back again... IDEAS?
Checking the wires and boots later this evening.
Any ideas where I should look next? Injectors?
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics | Retrofit LED / USB 3.0 | PC38 Pedal Commander | Alpine iLX-w650 w KTA450 | Kicker KS Series 6"x9" 3-way - CS Series 3/4" dome tweeters - KS Series 6-1/2" 2-way | Hifonics BXX1200.1D 1200W RMS 1 Ohm amp | Dual JL 10w6v2's |Q box 50hz
2011 Toyota 4Runner SR5 - Soundproofing | HU & Speaker Upgrades
Ph03n1x24 is offline   Reply With QuoteReply With Quote
Old 05-10-2023, 08:13 AM #2
OopsIBrokeIt OopsIBrokeIt is offline
OopsIBrokeIt will become famous soon enough
Ever done the head gasket? 03-05 V6s are known to have a flawed head gasket design that commonly results in cyl 6 misfiring.
Are you low on coolant or seeing signs of it pressurizing the system? Or have you had the coolant tested for exhaust gases?
OopsIBrokeIt is offline   Reply With QuoteReply With Quote
Old 05-10-2023, 12:30 PM #3
Ph03n1x24's Avatar
Real Name: Mark
Ph03n1x24's Avatar
Real Name: Mark
No issues thus far with the head gasket but now you have me thinking.
I am not low on coolant but will check it again. Other than the cel and the occasional rough idle on a cold start it's running great.
I guess I need to bite the bullet and take it back into the dealership and have them check the head gasket and coolant.
Thanks for the input!
Old 05-10-2023, 12:59 PM #4
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
With the engine running, do a wiggle test on the wiring and connector on #6 coil. Disassemble and visually inspect the wiring, the connector and the coil boot (look for tracking). Even though you just replaced the coils and plugs, I would swap the plug in 6 to another cylinder and the coil to a third cylinder. See if the misfire follows them. If not, the injector is the next obvious place to go. Visually inspect wiring and connector. Swap the injector on 6 to another cylinder and see if the misfire follows it.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
Old 05-10-2023, 02:00 PM #5
Ph03n1x24's Avatar
Real Name: Mark
Ph03n1x24's Avatar
Real Name: Mark
Thank you. I will do this over the weekend and report back on how it turned out.
Old 05-11-2023, 04:09 AM #6
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
P0304 is a misfire on cylinder 4, so there's something to consider in your troubleshooting.
waypoint is offline   Reply With QuoteReply With Quote
Old 05-11-2023, 10:43 AM #7
Ph03n1x24's Avatar
Real Name: Mark
Ph03n1x24's Avatar
Real Name: Mark
UPDATE: P0304 & P0306 Correction from original post.
Further troubleshooting I noticed something I hadn't seen before now. Green gook on a couple connector pins for No. #4 cylinder and No. #6 Cylinder.
Ordered some new coil wires. (I hope this rectifies the problem)
Will update once I swap those out this weekend.
Also, my memory wasn't as good as I thought it was regarding my original issue. Seems there was more going on back in 2019.
Here's a copy...
Old 05-17-2023, 04:25 PM #8
Ph03n1x24's Avatar
Real Name: Mark
Ph03n1x24's Avatar
Real Name: Mark
Here's a copy...
UPDATE: 05/17/23
Soooo, sheepishly I must admit I may have over complicated the issue. I was unable to get around to replacing the coil wires due to unexpected company and a heavy t-storm w/ subsequent power outage that hit us last weekend, here in the Houston area.
I did manage to top off the fuel tank last friday and by the time I got home from work on Monday the CEL was gone and it was running like a scalded ape. Then it dawned on me that right after I'd re-torqued the plugs I added a bottle of SeaFoam to a full tank of gas. That got me thinking, and then researching online. Duh, turns out it's rather common for SeaFoam to cause a cylinder misfire as it's doing its job.
So far so good! I will still change out the coil wires when I can as a preventative measure.
Thanks for all the great advice! This forum rocks!
Mark
back , p0304 , plugs , replaced , spark
Code P0304 misfire help mgcorreia 3rd gen T4Rs 11 09-21-2021 10:18 AM
P0304 misfire on cyl 4 code silver4est 3rd gen T4Rs 0 05-14-2019 10:34 PM
P0304 Misfire fixed (Injector) to P0171 System Lean CEL. tkc74 3rd gen T4Rs 7 11-21-2016 01:08 AM
stubborn o2 sensor aeb28 4th Gen T4Rs 18 07-24-2015 02:49 PM
