Old 05-11-2023, 09:48 PM #1
Flyer Flyer is offline
Flyer will become famous soon enough
A clunking when in reverse
These last few weeks, I noticed a bit of a clunking or a thump when in reverse, backing out of the driveway. It is a slight decline. It does not happen every time but maybe 50%+. Anyway, the 4R was in the dealership for a CV boot and brake job and they could find nothing. I have tried to look but can't find anything. It almost sounds like the clunk happens with each tire rotation but I cannot be sure.
Any thoughts on what I should look for? I asked them to check the driveshaft and the u-joints. All that checked out, according to the dealership. They could not reproduce it and they are busy so they may have only tried once. I'm at a bit of a loss.
2005 V8 4Runner 4X4 SR5, FJ TRD Bilstein Suspension, KO2s
2020 Mercedes GLE450
2014 Wrangler Rubicon, Synergy suspension + 35 MTRs + way too many mods
Flyer is offline   Reply With QuoteReply With Quote
Old 02-14-2024, 02:16 AM #2
AndroT100's Avatar
AndroT100 AndroT100 is offline
AndroT100 is on a distinguished road
AndroT100's Avatar
Just experienced the same issue with my 03 V8 4x4 SE this evening. In reverse in both 4hi and 4lo. Did it for several time when I was in reverse, then it went away....and then came back!
Did you ever find the reason and repair for this?
Thank you!
2003 4Runner Sport V8 4x4
AndroT100 is offline   Reply With QuoteReply With Quote
Old 02-14-2024, 08:57 AM #3
I replied. It was the rear axle seal on the right side. take it to a shop with a proper bearing puller.
Old 02-14-2024, 03:30 PM #4
mochacho mochacho is offline
mochacho is on a distinguished road
I had this issue too. Turns out it was my hitch shackle smacking against the reciever.....
mochacho is offline   Reply With QuoteReply With Quote
Old 02-15-2024, 10:06 PM #5
Bleu62 Bleu62 is offline
Real Name: Clay
Bleu62 is on a distinguished road
Real Name: Clay
I wouldn't go straight to the seal yet. I know someone had that issue but start w the small/ easy things first. Grease your driveshaft at full droop and see if that helps, then move to the next thing. Good luck!
Bleu62 is offline   Reply With QuoteReply With Quote
Old 02-16-2024, 07:36 AM #6
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Brake pad linear (front/back) movement
Sent from my SM-S908U using Tapatalk
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 02-17-2024, 11:59 AM #7
4R005 4R005 is offline
4R005 is on a distinguished road
@Flyer Did you applied parking brake on your inclined driveway ? Clunking noise with every wheel revolution can indicate a dragging brake shoe from a partially released brake cable from one or both rear wheels. Happened to my '05 some years back after I had applied the parking brake. Vehicle will give this clunk with each wheel revolution until after several hundred feet and then went away. Root cause was a partially seized driver side parking brake cable. Replaced cable and all is good afterwards.
4R005 is offline   Reply With QuoteReply With Quote
Old 02-17-2024, 01:55 PM #8
My issue was the left rear axle seal. The parking brake is good and my garage is level. I never park on the driveway. I thought of that first but that wasn't it.
Old 02-18-2024, 06:29 PM #9
@Flyer Thanks for the update on the fix. I'll store that into my memory bank if similar sound is heard from my '05 4R. BTW, what clue ( visible ?) led you to the left rear axle seal ( oil leak/seepage ? ).
Old 02-18-2024, 07:39 PM #10
Nothing visible but the clunk was getting worse and only coming from the rear left side. The shop took the wheel off and maybe the rotor off too and only then could they tell that the seal had failed and the bearing was toast.
bit , clunking , dealership , find , reverse
Clunking in reverse, where to start Wile.E.Coyote 4th Gen T4Rs 19 02-14-2024 12:30 AM
2000 limited, clunking in drive and reverse mtyink 3rd gen T4Rs 6 07-31-2014 01:32 PM
2007 cyclical clunking in reverse Monel 4th Gen T4Rs 2 06-12-2014 06:33 PM
Knocking / Clunking in reverse deziner75 4th Gen T4Rs 1 07-23-2013 07:05 PM
Clunking in reverse when braking gqr1c3boi 4th Gen T4Rs 8 02-09-2012 10:09 AM
