Originally Posted by 4Runner@504
I checked my ground from the battery to driver side fender and that is grounded
How did you check it? multimeter?
Have you checked the ground from the battery to the body in the engine compartment with a multimeter?
Has the vehicle ever been in a serious accident?
Do you have serious body rust?
What you're describing sounds like a poor connection between the battery (-) and the vehicle body. Look for a ground strap in the engine compartment and check it for corrosion or loose connection. Use a multimeter set to 20K or 200K ohms and see if the meter will read close to zero (no resistance)
