Old 05-13-2023, 09:43 AM #1
4Runner@504's Avatar
4Runner@504 4Runner@504 is offline
4Runner@504 is on a distinguished road
Driver side brake light ground issue
Good morning all I Jane a 2003 Toyota 4Runner limited edition and my driver side rear taillight has a grounding issue every time I apply my brakes the interior lights come on also my droner side blinker comes come bit don’t blink but has a very dim light when the brakes are applied this issue is only when my brakes are applied I checked my ground from the battery to driver side fender and that is grounded can someone help me thanks
4Runner@504 is offline   Reply With QuoteReply With Quote
Old 05-13-2023, 11:06 PM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
anything else was installed? remote start? reverse camera?
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK LTS pads F+R, Stoptech slotted rotors and stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 05-14-2023, 11:23 AM #3
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
How did you check it? multimeter?
Have you checked the ground from the battery to the body in the engine compartment with a multimeter?
Has the vehicle ever been in a serious accident?
Do you have serious body rust?
What you're describing sounds like a poor connection between the battery (-) and the vehicle body. Look for a ground strap in the engine compartment and check it for corrosion or loose connection. Use a multimeter set to 20K or 200K ohms and see if the meter will read close to zero (no resistance)
Rich
2004 V8 4Runner 138K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 05-14-2023, 12:52 PM #4
Thanks for the info there is no rust no accidents I checked the ground from the negative battery to the fender well that’s all
Old 05-15-2023, 10:04 AM #5
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
Replying to your PM here as well
The body/chassis of your car is the ground/negative for all/most of your electrical connections. Wires for the power/positive run through the wiring harness for all the different components; radio, lights, motors, etc. There is a grounding strap that goes from your battery's negative post to the car's chassis. If the wire has a bad or corroded connection at the chassis connection or at the battery negative post you will have all kinds of strange things happening.
DC electricity (all cars have DC electricity in the wiring) flows from high potential to low potential. If you have a poor ground connection then electricity looks for another low potential. This could be the positive wire on another device in the circuit. That is probably why your interior lights come on (dimly) when you step on the brake.
You don't say how you are testing the fender for a good ground connection. If you don't have a multimeter then try running a separate wire from the NEGATIVE battery post to the fender. Find a bolt on the fender (maybe in the wheel well area) and connect to that, then try your brakes, turn signal etc. If they work properly then you have a poor ground to the chassis.
Rich
Kentucky
Old 05-16-2023, 06:46 PM #6
d33pt d33pt is offline
d33pt is on a distinguished road
Do you have an aftermarket trailer light harness? If so, try taking it out.
d33pt is offline   Reply With QuoteReply With Quote
applied , brakes , driver , issue , side
Driver side brake light no workie look171 5th gen T4Rs 15 03-05-2020 10:01 AM
What is up with driver's side brake problems... RDOOGZ89 4th Gen T4Rs 9 10-28-2017 08:13 PM
Driver side rear brake = super hot ebg18t 4th Gen T4Rs 6 04-05-2013 10:04 AM
Front Driver's Side Strut Issue mshaner152 4th Gen T4Rs 29 04-12-2012 10:42 AM
driver side only reverse light and tag light out wiladc100 Classic T4Rs 3 11-21-2009 04:28 AM
