Real Name: brian
Real Name: brian
That might be the issue. You are using a rack not designed for a 4runner. Aerodynamics may be a part of it, lack of a foil in the front or not positioned properly might be part of it. A sunroof deflector might complicate things as it will deflect the air around the sunroof but might force it into the rack or they might just not work together.
I would take the rack off and see what happens. If the wind turbulence goes away then you have found your issue. If so then you have a decision to make, a functioning sunroof, a rack that may not be right for your 4runner, or just take it off when you're not using it.
Good luck.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
