Old 05-14-2023, 02:26 PM #1
Moist's Avatar
Moist Moist is online now
Moist is on a distinguished road
Moist's Avatar
Any way to disable the moonroof?
Have to get a fairing for my roof rack because the noise is unbearable. I just want to disable it so me or My passengers don't try to tilt or open it.
Sent from my SM-G973U using Tapatalk
Moist is online now   Reply With QuoteReply With Quote
Old 05-14-2023, 02:48 PM #2
214RUNNER's Avatar
214RUNNER 214RUNNER is offline
Location: THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
214RUNNER is on a distinguished road
214RUNNER's Avatar
Pull the fuse for the sun roof, or disconnect the switch & or motor.
214RUNNER is offline   Reply With QuoteReply With Quote
Old 05-15-2023, 06:48 PM #3
Moist's Avatar
Moist's Avatar
How would I go about disconnecting the motor or switch? Would that involve removing the ceiling trim or an I just overthrowing this.
The fuse removes the power windows and I quite like being able to go through drive throughs.
Old 05-15-2023, 07:16 PM #4
214RUNNER's Avatar
214RUNNER's Avatar
I’m not sure how the switch comes out maybe check youtube to see if there any videos for removing the switch.
Old 05-16-2023, 11:11 PM #5
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
Do you have a stock roof rack? Neither of my 4runners make noise when my sunroofs are open.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 05-18-2023, 09:29 PM #6
Moist's Avatar
Moist's Avatar
Nope, I have a YAKIMA rack from the 90s that originally fit a GEO prism and has just been mounted to the stock one. The deflector goes over the sunroof, and I already know my passengers will try to open it and break the new fairing.
Old 05-19-2023, 08:22 PM #7
inscarguy's Avatar
Real Name: brian
inscarguy's Avatar
Real Name: brian
That might be the issue. You are using a rack not designed for a 4runner. Aerodynamics may be a part of it, lack of a foil in the front or not positioned properly might be part of it. A sunroof deflector might complicate things as it will deflect the air around the sunroof but might force it into the rack or they might just not work together.
I would take the rack off and see what happens. If the wind turbulence goes away then you have found your issue. If so then you have a decision to make, a functioning sunroof, a rack that may not be right for your 4runner, or just take it off when you're not using it.
Good luck.
Old 05-22-2023, 01:40 PM #8
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
The assembly simply pulls out, from there just unplug the wiring harness to the sunroof motor.
eleven14 is offline   Reply With QuoteReply With Quote
disable , open , passengers , sm-g973u , tilt
3rd gen T4R moonroof disable mod. 5vzT4R 3rd gen T4Rs 58 03-26-2021 03:04 PM
moonroof delete/removing moonroof? Vtwinracersp2 5th gen T4Rs 23 09-11-2018 03:23 PM
Moonroof or not to moonroof; that is the question! PauldF 5th gen T4Rs 74 04-17-2018 03:41 PM
How can I disable the factory security/starter disable? jmyer72 3rd gen T4Rs 6 08-16-2015 08:32 AM
Sunroof/moonroof Niitehawkxe 3rd gen T4Rs 2 04-03-2005 03:10 PM
