Old 05-14-2023, 10:21 PM #1
parsky1 parsky1 is offline
parsky1 is on a distinguished road
2005 V8 SR5 oil leak near filter
I’m trying to track down an oil leak on a 2005 v8 SR5. Oil is all over the place from the filter back. Upper part of engine looks fine. The filter itself seemed relatively clean. I friend suggested oil cooler seals but I don’t think these have one?
2005 V8 SR5 oil leak near filter-img_6441-jpg
parsky1 is offline   Reply With QuoteReply With Quote
Old 05-14-2023, 11:53 PM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
That leak looks like it's coming from higher up. You can see some oil ready to drip off the bottom of the AC compressor in that picture. You sure the valve covers aren't leaking?
Also, why is that oil filter dented? It's shouldn't be unless it was removed and then reinstalled. It looks like someone used channel locks on it to remove it and then maybe reinstalled it for some reason. Your oil leak might be because the filter isn't seated properly and it's coming out from there.
My suggestion is to do an oil and filter change, clean up all that oil as best you can and then install a new oil filter. Watch for leaks over the next few days and see if it comes back. The oil filter should be seated and then turned at least 1/4 turn further once seated to be properly sealed.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
filter , fine , leak , oil , sr5
Oil filter leak. 2006 V6 new Mobil 1 filter nick168 4th Gen T4Rs 11 03-13-2019 04:25 PM
K&N Oil Filter Leak? UTEP 3rd gen T4Rs 17 01-18-2015 03:56 PM
Oil filter leak. Substantial amount zgensler31 3rd gen T4Rs 24 06-05-2014 12:11 PM
Coolant leak above oil filter lululalalu Classic T4Rs 1 04-10-2012 12:26 PM
oil leak on oil filter housing. dustyDtard Problems & Warranty Issues 6 03-29-2006 01:24 PM
