Old 05-22-2023, 12:37 PM #1
CO4x499 CO4x499 is offline
CO4x499 is on a distinguished road
First time doing rotor/brake pad swap. Should I do anything else while I'm at it?
I need new rotors and brake pads. I've never done the swap, but I'm reading through some DIYs. Is there anything else that's relatively simple I can or should do while I do this brake service?
CO4x499 is offline   Reply With QuoteReply With Quote
Old 05-23-2023, 11:47 AM #2
Loose Axles's Avatar
Loose Axles Loose Axles is offline
Real Name: Dillon
Loose Axles will become famous soon enough
Real Name: Dillon
Clean up the pins while you are in there. Clean up threads and Use anti seize on everything. With the wheel off it’s always good to check your bushings and look for any leaks. Check CV’s for wear, tie rods and rack for wear/leaks etc. Brakes are an easy one! Might be worth adjusting your parking brake as well if it isnt where you like it to be.
2007 V8 4Runner Limited.
https://www.toyota-4runner.org/4th-g...ld-thread.html
Calgary, Alberta.
Loose Axles is offline   Reply With QuoteReply With Quote
Old 05-23-2023, 06:34 PM #3
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
My advice (ask me how I know...) on this is to start with the cable under the console. See if tightening it (there are videos on YT) gets it where you want it. If not, loosen it a bit, use the star wheels under the rotors, then tighten it again. PM me for more if that doesn't make sense.
Bluesky 07 is offline   Reply With QuoteReply With Quote
brake , diys , reading , simple , swap
Brake Rotor size 02_SE_Runner_DAD 3rd gen T4Rs 3 08-24-2016 10:25 PM
Brake/Rotor Upgrade - HELP LillyWhite 2006 4th Gen T4Rs 1 11-18-2011 10:35 AM
Rear rotor swap, parking brake stuck ? project-roc 4th Gen T4Rs 2 09-08-2011 07:01 AM
Which Brake Pad and Rotor popalzai 4th Gen T4Rs 6 08-29-2011 02:43 PM
brake rotor differences? 90-92 Gryphon Classic T4Rs 2 03-21-2005 08:16 PM
