05-22-2023, 01:28 PM
Question about brakes 4th gen brake upgrade gone wrong.
Can someone help me relieve my doubts. I went to upgrade my brakes from 4th gen front brakes/rotors to 2010 5th calipers / rotors. Everything went great until I went to bleed the brakesÂ…. The rears went great (upgraded calipers to 5th gen , rotors new 4th gen) then I went to bleed the fronts. Brake pedal goes soft. After many attempts, I covered the fitting going into the caliper with grease and noticed that air escaped from both calipers thru the grease when I tried to bleed the front brakes. One of the calipers had the first thread stripped (shipped that way) figured it would be ok since it was only the first thread. DonÂ’t understand why the other caliper would be leaking tho. So long story short, can someone tell me that the brake fitting (that goes into caliper) are the same from 4th gen to 5th?? I read a couple of threads on the upgrade before doing this and I donÂ’t recall seeing anything about having to change brakes lines.
05-22-2023, 06:01 PM
Real Name: Skip
Real Name: Skip
I don't know for sure but the fittings should be the same, I would take the calipers back to where you bought them and get another set.
2004 Limited V8
05-22-2023, 06:45 PM
Real Name: Todd
Real Name: Todd
I would agree with this. I've done the 5th gen brake upgrade on mine, got all my calipers from RockAuto.com and had zero issues. Fittings were standard between my original calipers and the 14WA calipers.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
05-23-2023, 01:03 PM
Real Name: Dillon
Real Name: Dillon
Which kit did you end up going with? TIA!
2007 V8 4Runner Limited.
https://www.toyota-4runner.org/4th-g...ld-thread.html
Calgary, Alberta.
05-23-2023, 03:53 PM
Real Name: Todd
Real Name: Todd
I didn't go with a kit. I literally ordered the front brake calipers for a 2010 4Runner and stuck with new rear calipers for my 2003 from RockAuto.com. I got brake pads and EBC rotors off Amazon and already had braided brake lines installed.
It doesn't take a kit to do the brake upgrade to the 5th gen calipers, it takes knowledge and a little shopping. Make your own kit with parts you know are going to work.
05-23-2023, 05:31 PM
Real Name: Dillon
Real Name: Dillon
Sorry I should have clarified, I just meant which combo of calipers, rotors, and pads you went with haha. Thanks for the info! I am planning to do the 5th gen upgrade sooner than later here.
Calgary, Alberta.
05-23-2023, 07:11 PM
Real Name: Todd
Real Name: Todd
14WA front calipers, which are standard for 2010-2015 4Runners (Think I have those dates right).
Rear calipers are stock replacement for 2003-2009, the later model rears are not an upgrade.
Akebono ceramic brake pads. The below links are correct, however they seem to have the pics swapped for front and rear.
Amazon.com
Amazon.com
EBC Sport Series slotted rotors front and rear:
Amazon.com
Amazon.com
05-23-2023, 11:03 PM
Real Name: Dillon
Real Name: Dillon
Amazon.com
Amazon.com
Amazon.com
Amazon.com
You’re the man! Thanks so much!
Calgary, Alberta.
05-24-2023, 12:19 AM
Real Name: Todd
Real Name: Todd
Here are the calipers I used:
Front calipers are 2010-15 4Runner 14WA PowerStop remans.
Front left - More Information for POWER STOP L6279
Front right - More Information for POWER STOP L6278
Rear calipers are also PowerStop remans but stock replacements for the 2003-09 4Runner.
Rear left - More Information for POWER STOP L2727
Rear right - More Information for POWER STOP L2726
To convert all the rubber brake lines over to braided lines, you have to use several sources. I got the body to axle center brake lines from metaltech4x4 - 4Runner & FJ Cruiser Extended Stainless-Steel Brake Lines
The wheel well brake lines I got from Crown Performance. They have kits for stock to 3" or 4" lifts - https://www.crownperformance.com/4runner/
The rear calipers have a rubber line from the axle to the caliper. StopTech makes braided lines to replace those - https://www.amazon.com/StopTech-950-.../dp/B003K3NBPA
Page 24, post 468 of my build thread on Tacoma World has more details on the brake swap. https://www.tacomaworld.com/threads/...651589/page-24
