Old 06-04-2023, 11:14 AM #16
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
Why not get bulbs that have the built in resistors or ones that are non hyperflash. I have them in both of mine plus I ground down the resistor in the flasher.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 01-12-2025, 09:00 PM #17
Denver4thGen's Avatar
Denver4thGen Denver4thGen is offline
Denver4thGen is on a distinguished road
Bulbs with built in load resistors.
Hi everyone,
It seems there's an easy solution. According to YouTuber, he purchased bulbs with built in load resistors.
I went the same path as him. Since I have DRL, I couldn't do the new relay and didn't want to grind down the resistor on the relay. And, I didn't want to monkey with resistors and start splicing good Toyota wiring.
I ordered both of the bulbs with built in resistors and I'll report back my results. Hopefully it works!
AUXITO 7440 Amber LED Turn Signal Light Bulbs Anti Hyper Flash Canbus Error Free | eBay
AUXITO Amber 7443/7440 LED Front Turn Signal Light Bulbs No Hyper Flash Canbus A | eBay
Denver4thGen is offline   Reply With QuoteReply With Quote
Old 01-12-2025, 09:52 PM #18
simple's Avatar
simple simple is offline
simple will become famous soon enough
simple's Avatar
Originally Posted by Denver4thGen View Post
Hi everyone,
Are you saying those bulbs should be plug and play and work with DRL too? I watched the video, and it was only the rears, but you're making it sound like the fronts will work too
Air 4rceRunner One, 04 Sr5
simple is offline   Reply With QuoteReply With Quote
Old 01-14-2025, 09:05 PM #19
Yup, they should be. And, there are several units the companies claim will work. I'm going to try them all until something works and report back. I like the ones from amazon since they have a fan and since these are using a built in resistor, there may be heat. I'm waiting on them in the mail. Once I have a solid result, I'll post.
This company: https://www.headlightrevolution.com/...ree?quantity=1
And three from AUXITO:
1: Amazon AUXITO: https://a.co/d/b1d7Eef
2: eBay AUXITO: AUXITO Amber 7443/7440 LED Front Turn Signal Light Bulbs No Hyper Flash Canbus A | eBay
3: eBay AUXITO: AUXITO 7440 Amber LED Turn Signal Light Bulbs Anti Hyper Flash Canbus Error Free | eBay
Old 01-15-2025, 09:44 AM #20
Ventil8 Ventil8 is offline
Real Name: Armando
Ventil8 will become famous soon enough Ventil8 will become famous soon enough
Real Name: Armando
I’ve had the Auxito LED turn signal bulbs with built in resistors on the front and back turn signal bulbs. Plug and play and much brighter. Highly recommended.
Original Owner- 2005 Silver Metallic Sport Edition 4WD V6
Ventil8 is offline   Reply With QuoteReply With Quote
Old 01-15-2025, 10:44 PM #21
simple's Avatar
simple's Avatar
Nice, Thanks!! Any issues with heat, or them being TOO bright? Also, did you have DRL, and if you did, do you still have them?
Old 01-16-2025, 08:08 PM #22
I went with this Amazon for the rear and this Amazon for the front. The socket on the front is different than the rear. There is no hyper flash, all plug & play. I do have DRL.
I've been running them for a few weeks, everything is working fine.
Old 01-16-2025, 11:51 PM #23
simple's Avatar
simple's Avatar
I went with the Amazon (1) for the rear and the ebay (2) for the front. The socket on the front is different than the rear and won't take the amazon unit. There is no hyper flash, all plug & play. I do have DRL.
Nice, thanks for the update!
flash , issue , leds , signal , turn
FS: 5th Gen Lasfit front turn signals. Canbus no Hyperflash no resistor Bayonne Nj 0 skillzo1 For Sale: T4R Items 1 04-05-2020 10:29 AM
Demello LED turn signal and hyperflash- Has anyone solved this issue with a resistor? PAULUNM 4th Gen T4Rs 7 11-05-2014 11:30 PM
Help turn signal mod 2001TR4runner 3rd gen T4Rs 3 09-25-2014 08:51 PM
Turn signal mod ARC 3rd gen T4Rs 10 05-27-2014 03:17 AM
3rd gen turn signal solution... Limbwalker 3rd gen T4Rs 5 09-22-2013 02:30 AM
