Old 05-31-2023, 04:16 PM #1
benztech82's Avatar
benztech82 benztech82 is offline
benztech82 will become famous soon enough
benztech82's Avatar
Hard pulling to the right
Hey all!
I got a weird one and it's driving me crazy now.
I have 5100 at 0 clip with OME springs, freedom offroad both upper and lower control arms, no play in any ball joint, calipers are not seized, tires are balanced, belts not shifted, intermidiate shaft replaced, no play in the steering. Alignment just done and I was watching it being done.
What else I should replace?
Sent from my SM-N975W using Tapatalk
benztech82 is offline   Reply With QuoteReply With Quote
Old 06-01-2023, 11:14 PM #2
Bleu62 Bleu62 is offline
Real Name: Clay
Bleu62 is on a distinguished road
Real Name: Clay
Are the tires the same? I work on planes for a living and a write up kept coming back that it would turn to the left for a couple weeks straight. Psi was good, no unbalance issues but after the same write up coming back the tire was about 2 inches shorter for the left nose wheel tire compared to the right. Same pn on both anyway long story long.
Bleu62 is offline   Reply With QuoteReply With Quote
Old 06-02-2023, 10:25 AM #3
benztech82's Avatar
benztech82's Avatar
I realized that when I drive slow like crawling almost, the steering wheel is almost pulsating/forcing truck to go to the right side. I think its related to tires too now. They are evenly worn but! Apparently, Cooper ST Max are known for right side pulling.
Pulling right, Cooper ST Maxx. Pic of Alignment Report | Tacoma World
So, I want to rotate the right-side tires on the rim and hopefully it will help.
Also, I have a tundra that can borrow tires on rims to check.
Old 06-02-2023, 04:36 PM #4
stevelikesrhino stevelikesrhino is offline
stevelikesrhino is on a distinguished road
Looking at your alignment chart, it does look like your right front caster is out of spec and almost 2 degrees lower than left front caster. Maybe ask the shop to re-adjust it. Note the preferred caster is around 3 degrees but your RF is at 1.3 now. Caster, if left and right is in sync, mainly affect the stability of your steering. IIRC your upper control arm is not adjustable, so they may have to use camber bolts to push the lower ball joint forward.
stevelikesrhino is offline   Reply With QuoteReply With Quote
Old 06-03-2023, 07:36 PM #5
benztech82's Avatar
benztech82's Avatar
It won't go past 1.3. Other side can go all the way to 4.5 but r/s won't, it stops at 1.3 it's a max adjustment. Not sure why. The alignment tech told me that caster won't create a pull to the side.
calipers , play , replaced , seized , sm-n975w
New 5th gen pulling to the right under hard brake Ghetro 5th gen T4Rs 11 02-26-2014 06:16 PM
Clunk after semi hard/hard braking NCrunner2012 3rd gen T4Rs 18 07-10-2012 12:04 PM
Hard Clunk While Pulling Out of Garage Black T 5th gen T4Rs 5 04-26-2011 08:22 AM
Hard Breaking Transmission Downshifting kind of Hard RHINO-99 4th Gen T4Rs 1 05-18-2009 01:06 PM
