Originally Posted by AuSeeker
I think the line should be replaced....but I don't think it's the issue, if it was then when you opened the bleeder valve the rotor should of turned freely and you say it only slightly got better, that tells me that either the piston is seized or the guide pins need to be lubricated or both.
+1 It doesn't look kinked enough to me to completely stop the flow back and these trucks are notorious for bad calipers but yours is new. Do make sure the pads move freely on both sides of the disk.
