Old 06-06-2023, 10:45 PM #1
ScooterMD's Avatar
ScooterMD ScooterMD is offline
ScooterMD is on a distinguished road
ScooterMD's Avatar
Kinked Steel Brake Tube (maybe), brakes frozen
While replacing the brake caliper and pads, when I had the caliper removed from the knuckle and hanging from a bungee, it twisted around and it looks like it may have kinked the steel tube connected to the caliper.
After reconnecting the caliper and bleeding/pumping the brakes, this caliper's pistons appear to be frozen, such that turning the rotor is extremely difficult. The other rotor/caliper is totally fine.
Although it's possible the new caliper is frozen/defective, I suspect the steel brake tube may be essentially compressed/collapsed internally, such that, once the pistons are pressurized by pumping the brakes, that pressure is trapped inside the pistons, keeping the brakes pads compressed against the rotor. Has anyone seen this before?
I tried opening the bleeding valve and it does make turning the rotor slightly easier. Before I just go and buy a new steel tube and restart the process of bleeding, was wondering if this is something other people have encountered. That is, whether a kinked steel brake tube will disallow the brake pistons to release pressure, thus keeping the pads compressed against the rotor.
Thanks in advance.
Kinked Steel Brake Tube (maybe), brakes frozen-tube-jpg  Kinked Steel Brake Tube (maybe), brakes frozen-bend-jpg
07 Sport V6
ScooterMD is offline   Reply With QuoteReply With Quote
Old 06-06-2023, 11:16 PM #2
maxdef maxdef is offline
maxdef will become famous soon enough
I don't know for sure if it did fail, but I do know that both sides are very inexpensive and you should just replace it. I did and I'm pretty sure it added either +5hp or -5 brake time.
Tube | Part #4731435320 | Toyota Auto Parts
Front Left/Driver: 47314-35320
Front Right/Pass.: 47316-35320
(Short end is caliper side)
maxdef is offline   Reply With QuoteReply With Quote
Old 06-07-2023, 12:00 AM #3
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
I think you have diagnosed your problem. The bent brake line is probably preventing the return of the fluid. Your applying more pressure with the pedal to energize the caliper than will release on its own. If you can just buy the formed brake line then that's the best solution.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 06-07-2023, 12:31 AM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I think the line should be replaced....but I don't think it's the issue, if it was then when you opened the bleeder valve the rotor should of turned freely and you say it only slightly got better, that tells me that either the piston is seized or the guide pins need to be lubricated or both.
2004 Limited V8
Old 06-07-2023, 04:25 PM #5
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
+1 It doesn't look kinked enough to me to completely stop the flow back and these trucks are notorious for bad calipers but yours is new. Do make sure the pads move freely on both sides of the disk.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
brake , caliper , rotor , steel , tube
Frozen Brakes Mudeprived 3rd gen T4Rs 19 12-31-2017 06:36 AM
frozen brakes? AndreiR 3rd gen T4Rs 5 02-19-2015 02:17 PM
Brakes frozen/locked up samwalters 3rd gen T4Rs 2 10-19-2014 06:23 PM
Aluminum vs Steel tube bumper? AF808fighter 3rd gen T4Rs 1 02-14-2012 03:33 PM
Brakes- frozen, maintenance, tips DiskDoctr 4th Gen T4Rs 1 12-15-2010 06:55 PM
