Old 06-23-2023, 02:04 AM #1
Sabaka Sabaka is offline
Sabaka is on a distinguished road
Interior and Luggage Compartment Light Issue
I have a 2007 TR4 Sport Ed, V6. When the switch for the interior light on the ceiling over the front seats is set to door, it turns on regardless of whether any of the 4 doors is open or closed. Similarly, when the switch for the luggage compartment light at the back of the cabin is set to door, the light turns on regardless of whether the lift gate is open or closed.
The courtesy lights in each of the four doors turns on when the door is open and turns off when the door is closed.
If I'm looking at the correct wiring diagram (and reading it correctly), each switch in a door is connected to the body ECU. When the door opens, the door switch pulls the line to ground.
The interior and luggage compartment lights are provided with power regardless of switch position on those lights. When the switches for those lights is set to door, the other line to the light is connected to the ILE 13 pin of the body ECU. I assume the ECU pulls this line to ground when a door is open, which turns the light on.
It looks like my issue is a bad ECU. It looks like the ECU pulls the line to interior and luggage compartment lines to ground all the time. I'm looking for input from someone with more experience than me as to whether this makes sense or if I'm overlooking something.
Thanks in advance.
Sabaka is offline   Reply With QuoteReply With Quote
Old 06-23-2023, 08:49 AM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
it might be a bad door pin switch, you can take it apart and clean it out and see if any corrosion and such.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 06-23-2023, 09:58 AM #3
ricerulz ricerulz is offline
ricerulz is on a distinguished road
It does seem like your door switches are ok because the courtesy lights are functioning but it only takes 1 bad switch to control the interior lights. That includes the hatch which doesn't have any courtesy lights to check.
I wouldn't jump to an internal issue with a body control module without chasing some wires first. If the lights are really being controlled on the ground side (I hate it when electrical is run like that) then a slight abrasion anywhere on the wire could be shorting it to ground anywhere in the system.
2005 V6 4Runner:
https://www.toyota-4runner.org/4th-g...low-build.html
ricerulz is offline   Reply With QuoteReply With Quote
Old 06-23-2023, 10:21 AM #4
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Maybe my 2004 is different. Both of those switches in mine are 3-way: always off, always on and door. I have the 330 watt radio with the rear seat headphone option and controller, so that light over the front is larger to accommodate the infrared receiver, but the switches for both lights work the same.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 06-25-2023, 08:00 PM #5
miller507's Avatar
miller507 miller507 is offline
miller507 will become famous soon enough
miller507's Avatar
Highly doubt is an ecu issue along with the wiring, feels more like a faulty switch or contact issue, keep in mind it does have 16 years of wear and tear.
My 03 did that after I switched to led interior lights, little wiggle of the switch and forgot about it.
Cabin and cargo area light up regardless of what door you open when both set to "door" also when unlocking. At least mine does.
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3 retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
miller507 is offline   Reply With QuoteReply With Quote
Old 06-26-2023, 10:16 PM #6
Thank you for the comments, especially that it only takes one bad switch to cause a problem. I initially assumed each of the door switches were okay because they worked to control the corresponding light in the door. However, I had overlooked the switch for the hatch. After a little research, I realized that the switch for the hatch is within the latching mechanism, which is more difficult to get to than door switches in the door jambs. The switch in the hatch seemed like the problem, but since it's a lot more work to get to I thought I would check the the door switches first just in case.
When a door is open, I think the door switch connects the dome light and door light (via the ECU) to ground. Removing the bolt holding the door switch in and pulling the switch away from the body, removes the path to ground for the two lights. For all doors, removing the door switch caused the door light to go off, but the dome light remained on, with one exception. This seemed to confirm that three of the switches were good. The exception was the rear passenger door. I think it stayed on and then tuned off.
I repeated the process and confirmed that disconnecting the switch for the rear passenger door turned off the dome light. I thought I found the problem. I was deciding whether to pay $32 to get a new switch from Autozone today or order one from Rockauto for $15 and get it in a week, when I thought I would double check that the switch was bad.
I disconnected the switch for the rear passenger door. The dome light went off with a delay. Then I opened and closed each of the other three doors. Opening a door caused the light to go on. Closing the door caused the light to go off, but with a delay.
I'm now thinking all the switches are good and I simply didn't realize or forgot that there is a delay of about 15 seconds before the dome light goes off.
Old 06-26-2023, 11:43 PM #7
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
Yes there is a delay unless you click the lock doors button on the remote, then the dome lights go out, at least on my 2004
Rich
Kentucky
Old 06-27-2023, 02:45 PM #8
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
This is interesting to me as I read all the replies. I've been scouring the EWD for the dome light circuit for the last two weeks while chasing a fuse blowing issue. I did find the cause of the fuse blowing issue but seemed to have created "dome light on for ten min" issue when all doors are closed.
Since the rear hatch door latch has been mentioned, I did replace the latching mechanism last year when the OEM went south. I wonder if this replacement mechanism is the cause of my dome lights staying on for ten min after I close the last door, then go for a drive, or walk away from the vehicle without alarming (at my house for ex).
Some things for me to ponder. If you have any feedback on my issue, please post up here so that we can all learn and not muck up this thread.
Dome light staying on after doors are closed and door open indicator not on
The BCU does have a 15sec delay after the last door is shut.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
door , ecu , light , switch , turns
LED Engine Compartment Light amir_gh 5th gen T4Rs 3 03-21-2020 10:07 AM
Rear luggage light and door adjar light go on when offroading on washboard roads randy88fj62 4th Gen T4Rs 1 11-18-2019 09:27 PM
interior LED install issue on map light jmf_tracy 5th gen T4Rs 12 02-09-2016 12:13 PM
engine compartment + light 3bears 3rd gen T4Rs 12 01-18-2016 08:00 PM
Glove compartment light Gecko123 4th Gen T4Rs 2 11-26-2013 12:02 PM
