Old 06-23-2023, 12:24 PM #1
knightsfs4's Avatar
knightsfs4 knightsfs4 is offline
knightsfs4 is an unknown quantity at this point
knightsfs4's Avatar
P0358 Code: Ignition Coil H Primary/Secondary Circuit Malfunction
I recently had a code on my 06 V8 saying that cylinder 8 was misfiring. I went through and replaced all of the spark plugs, and I replaced the ignition coil for cylinder 8.
After I did this, the initial code for the misfire went away. But now I have this code P0358 Code: Ignition Coil H Primary/Secondary Circuit Malfunction
I did some research and saw that most info said to change out the ignition coil, which I already did.
Anyone else have any experience with this and are willing to share some info on how to solve this?
Thank you.
Knightsfs4 Build Thread http://www.toyota-4runner.org/4th-ge...ld-thread.html
Jack-Purchased on 11/22/10- 2006 Limited 4X4 V8
knightsfs4 is offline   Reply With QuoteReply With Quote
Old 06-23-2023, 04:57 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Swap the coil with another one and see if the code triggers again and follows to the new location, if it does then the new coil could be bad out of the box.
2004 Limited V8
code , coil , ignition , p0358 , replaced
2005 V8 engine - Gaining access to the secondary air pump circuit bergs 4th Gen T4Rs 31 11-02-2023 12:52 PM
Air-Fuel Ratio (A/F) Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) vipblades 3rd gen T4Rs 33 10-25-2014 11:06 AM
