Old 07-01-2023, 09:56 PM #1
timbird1219's Avatar
timbird1219 timbird1219 is offline
Real Name: Tim
timbird1219 is on a distinguished road
Real Name: Tim
VSC TRAC and VSC OFF lights on
Hey maybe someone has had this issue before. For starters I have a 2003 t4r and when I start her up no lights in the dash are on however as soon as she goes into gear and pulls forward or reverse a little bit those to lights come on. Has anyone seen this before if so how did you fix it. My sister had the same issue for her 03 Highlander and she replaced the gas cap so I tried that but nope nothing yet. Any other ideas?
timbird1219 is offline   Reply With QuoteReply With Quote
Old 07-01-2023, 10:39 PM #2
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
Do a search for “vsc/trac off lights” here on the forum. I had the same problem, and a zero point calibration fixed it. The relevant thread is from 11/2/14. Somehow, the vehicle loses the stored data that says it’s level.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 07-05-2023, 10:49 AM #3
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
plus 1 on the zero point calibration try.
If that doesn't work I would start pulling codes to see if there is anything that comes up, not likely since I would expect the check engine light to be on as well.
For what it's worth, if you didn't want to rig up your own wires to do the at-home zero-point calibration I can confirm that this OBDii scanner from amazon will perform the zero-point cal successfully. Not the most intuitive thing to use, but you can search it up on youtube and there is a guy that walks through the steps of clearing out the stored settings and running the zero point cal using this thing : Amazon.com
2003 Limited V8 4runner - Slowly turning back to stock (until the next crazy idea comes along )
aemravan is offline   Reply With QuoteReply With Quote
Old 07-08-2023, 05:47 PM #4
MrTom's Avatar
MrTom MrTom is offline
MrTom is an unknown quantity at this point
MrTom's Avatar
I recently fueled up with 85 octane . Next time I restarted the lights came on. Shop said codes showed drivers cat converter.
They said next fill up use 89+ . Eventually the lights cleared and I make sure to use 87 octane with no issues.
I did a test of 85 octane and lights came on again and cleared with a tank of 87.
2003 Sport V8 4x4 189, 000 miles
03 4Runner Sport V-8 4WD
MrTom is offline   Reply With QuoteReply With Quote
Old 07-08-2023, 09:39 PM #5
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
You had a CEL which will also trigger the VSC/TRAC lights. The OP ONLY has VSC/TRAC, no CEL. This is most commonly caused by the computer loosing it's calibration for when the vehicle is level. A Zero Point Calibration is the fix for that, not changing you fuel.
FYI, 89 is the more stable octane rating and better fuel to use over 87. Never use less htan 87 either way.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
fix , issue , lights , replaced , vsc
Check engine light, VSC TRAC & TRAC OFF lights crainmain Maintenance/Detailing 120 11-22-2023 07:11 PM
2003 4Runner- VSC Trac/ Trac Off Lights Only coolvman83 Problems & Warranty Issues 13 10-30-2019 11:05 AM
VSC TRAC and TRAC OFF Lights Stay On danielatx Problems & Warranty Issues 4 12-11-2014 12:50 PM
Check engine light vsc trac & trac off lights come on piptraderfx New Members 5 03-14-2014 07:47 AM
2006 V8 2WD CEL, VSC TRAC, TRAC lights all on... T4RPILOT 4th Gen T4Rs 4 10-10-2012 12:29 PM
