Old 07-16-2023, 07:50 AM #1
BOSMECH's Avatar
BOSMECH BOSMECH is offline
Location: Stockbridge GA. ( formerly Kent WA. ) & ( formerly Grafton MA. )
BOSMECH is on a distinguished road
BOSMECH's Avatar
Fuel door hinge pin
Has anyone experienced a broken fuel door hinge pin being broken.
And if so how did you fix it?
I have my own ideas but just want some input.
Per Toyota you need to take the door off, but that still wont really help.
2003 SR5 V6 4WD Stock (totaled)
2005 Sport Edition SR5 V6 4WD
BOSMECH is offline   Reply With QuoteReply With Quote
Old 07-17-2023, 04:38 PM #2
MikeinNH67's Avatar
MikeinNH67's Avatar
Pretty common issue on Siennas, including mine, but haven't seen it here yet. Maybe look at some of the Sienna repair videos on YT to see if it's a similar issue?
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 07-18-2023, 08:31 AM #3
BOSMECH's Avatar
BOSMECH's Avatar
I looked at YT and saw some videos and got a pretty good idea of what to do.
As a aircraft mechanic I have access to a lot of materials so I will use some stainless steel pin/rod and fix it.
Old 07-18-2023, 09:12 AM #4
Bassturd's Avatar
Bassturd Bassturd is offline
Bassturd has a spectacular aura about Bassturd has a spectacular aura about
Bassturd's Avatar
Pretty sure you can just order a new rivet for a few bucks and use your favorite rivet tool to install. I just did a rough search for a fuel door rivet multiple Toyota dealers popped up under $3 good luck.
2004 SR5 V8 AWD
Bassturd is offline   Reply With QuoteReply With Quote
Old 07-18-2023, 03:40 PM #5
MikeinNH67's Avatar
MikeinNH67's Avatar
I don't recall what my 4runner looks like as I've never had an issue with it but if it's like the rivet on my Sienna you would need a big rivet gun. I plan on using nuts and bolts when I repair the van.
Mike
03 4runner Limited
Old 07-19-2023, 08:34 AM #6
Bassturd's Avatar
Bassturd's Avatar
IIRC itís a 1/4Ē rivet
2004 SR5 V8 AWD
Old 08-19-2023, 08:55 PM #7
BOSMECH's Avatar
BOSMECH's Avatar
Well, I got some stainless-steel rod from work and finagled it in without drilling the rivets out.
Ethier way it is done but if you drill the rivets out you still have to remove the pin and is not easy cutting it was just as easy for me, I used basically a Dremel tool to cut it but my new pin does not go into the holder position, but it will not come out.
broken , door , fuel , hinge , pin
Broken fuel door hinge Kmvreter 4th Gen T4Rs 48 09-19-2018 11:44 AM
upper door hinge barrylee66 Classic T4Rs 2 03-18-2012 08:31 AM
1st GEN Door Hinge Problem Mpower3 Classic T4Rs 4 09-06-2011 09:55 PM
Bent door hinge CapnRoo Problems & Warranty Issues 1 01-19-2011 01:17 AM
Door hinge noise crs996 3rd gen T4Rs 7 12-23-2009 03:56 PM
