Old 07-22-2023, 05:08 PM #1
tylrdvs277's Avatar
tylrdvs277 tylrdvs277 is offline
tylrdvs277 is on a distinguished road
tylrdvs277's Avatar
Clunk when steering
Hey all,
Looking for some help diagnosing this issue. This seems to happen mostly when when moving. Basically when I turn slightly off center to the left and then turn back right again I can feel a clunk through the steering wheel. This doesn’t happen when I turn back left after turning right. Any idea if there is some component I should take a look at or does my steering rack just have some play in it due to its age
2008 4Runner V8 4WD Limited (Dobinsons 2.5 inch lift, JBA UCAs, 265/65r18 KO2s)
tylrdvs277 is offline   Reply With QuoteReply With Quote
Old 07-22-2023, 10:06 PM #2
PaluxyRiverRunner PaluxyRiverRunner is offline
PaluxyRiverRunner is on a distinguished road
You can check your steering components with a jack and a pry bar. Place the jack under the lower control arm and raise the vehicle until the tire is off the ground enough to get your pry bar under it. Make sure the vehicle is stable on the jack. Place your hands on tire at 3 and 9 o'clock and push and pull on both sides. Any moment here wound be steering linkage/gear or wheel bearing. If it is coming from the steering linkage you can isolate by holding the tie rod while pushing/pulling. Prying up from under the tire will check the ball joints. Pushing/pulling at 12 o'clock will check the upper ball joint and wheel bearing.
2006 4Runner Sport 4x4
ASE certified Master Automotive Technician with L1 and L4 Advanced Level Certifications.
PaluxyRiverRunner is offline   Reply With QuoteReply With Quote
Old 07-22-2023, 10:08 PM #3
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Last part that clunked in mine was the intermediate steering universal joint shaft. Was about $180 from a dealer for the whole part even though just the U joint is bad.
A little bit of a pain to put on only because the splines get seized together, but some hammering and it's off.
A couple bolts in the engine bay and a bolt or two under the steering column.
gaber6 is offline   Reply With QuoteReply With Quote
Old 07-23-2023, 11:58 AM #4
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
+1 for intermediate steering shaft. Mine went at 190k. You can try spraying some lubricant on the u joint and drive around for a bit. If you don't feel the clunk or feel it less, that's your culprit.
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 07-24-2023, 06:41 PM #5
MikeinNH67's Avatar
MikeinNH67's Avatar
I would also look at the intermediate steering shaft first. If in the past you had hard notchy steering then that would be the first step of it wearing. Worn inner or outer tie rods can also give a side to side clunk. Best bet is with the key on and engine off, have someone turn the wheel side to side a bit so you can listen for clunks. When you have the area the noise is coming from to focus on, you can often see the loose part.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 07-26-2023, 08:47 AM #6
TTucker TTucker is offline
TTucker is on a distinguished road
intermediate steering universal joint shaft fixed mine
TTucker is offline   Reply With QuoteReply With Quote
Old 07-26-2023, 09:53 AM #7
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
are you only able to reproduce when moving? Or will sitting still in the driveway cause the same noise? if you can reproduce it in the driveway my suggestion would be to have some one steer it for you while you look and feel around. Otherwise, I would likely start with the intermediate shaft as already stated, but balljoints are also very likely to clunk during steering as they start to wear. Assuming you're on factory lower and upper arms?
2003 Limited V8 4runner - Slowly turning back to stock (until the next crazy idea comes along )
aemravan is offline   Reply With QuoteReply With Quote
Old 08-16-2023, 07:25 PM #8
tylrdvs277's Avatar
tylrdvs277's Avatar
Thanks for all the input everyone! After posting this, I took the truck to an alignment shop. I let them know the issue. They did an inspection and aligned it. They told me they saw no issues with the control arms, ball joints, tie rods, etc. and they too thought it would be in the steering somewhere. I got the parts and I’ll replace the intermediate steering shaft and see what happens
Old 08-16-2023, 11:12 PM #9
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Outer CV axle joint. Check for lateral play.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 08-17-2023, 05:19 PM #10
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
Subscribing to this thread to see if the clonk issue is fixed with a new intermediate steering shaft.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
back , happen , left , steering , turn
Intermediate Steering Shaft Replacement - fixed steering clunk! Lamer 3rd gen T4Rs 7 08-06-2022 08:00 PM
Steering clunk... clunk over hard bumps kruegs 3rd gen T4Rs 30 12-12-2017 03:50 PM
Steering click, or pop, or clunk? 907YOTA 4th Gen T4Rs 6 11-18-2017 07:27 PM
Steering clunk at low speeds Jay1044 3rd gen T4Rs 7 10-02-2013 02:23 PM
5th gen steering pop/clunk srcbstrd 5th gen T4Rs 1 05-27-2012 12:07 AM
