Old 07-24-2023, 10:45 AM #1
coolkidd coolkidd is offline
coolkidd is on a distinguished road
O2 sensor spacers
I had the catalyst issue a few years back. Replaced the cats/manifolds and the 02 sensors. Was good for a while now I’m getting the codes again. I was told if I used aftermarket parts I’d need to install 02 sensor spacers due to the computer being extremely picky with aftermarket stuff.
Has anybody used spacers and if so what would you recommend.
Thanks in Advance
coolkidd is offline   Reply With QuoteReply With Quote
Old 07-24-2023, 11:06 AM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
V6 or V8?
You say you replaced the manifolds and O2 sensors a few years back and are getting codes again. My first question is did you use OEM parts or aftermarket replacements?
Aftermarket parts work but will not last as long as OEM parts. Sensors should be replaced with Denso or OEN, which happens to be Denso. Aftermarket cats/manifolds work for a few years but the material for the cats is no where near as good as the OEM stuff and they don't last.
Using O2 spacers is basically a band aid for the actual problem. Replace the parts with OEM parts and make sure the rest of the maintenance is up to date on the vehicle.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 07-24-2023, 12:07 PM #3
Originally Posted by xtremewlr View Post
V6 or V8?
It’s the v6. I did use aftermarket manifolds/cats with denso 02 sensors. I replaced these 5 years ago, I would have assumed they would last longer then that?
Old 07-24-2023, 04:04 PM #4
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Aftermarket cats can fail within 5 years or less, or you might get lucky and they last longer. OEM cats will most certainly last around 100k miles or more. I've got over 337k miles on my original OEM cats with my V8 and They are just now giving me issues and throwing O2 codes, even with new Denso sensors. I'll be replacing the manifolds with OEM again. Little more expensive but they are proven to work and last longer than the cheaper aftermarket ones.
Old 07-24-2023, 04:30 PM #5
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
I'm all for band-aids in this case. Certainly not putting OEM cats on my rust bucket. I'll be trying the spark plug spacers on mine that has an intermittent p0430.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 07-24-2023, 04:44 PM #6
HIMILESV8SPORT's Avatar
HIMILESV8SPORT HIMILESV8SPORT is offline
HIMILESV8SPORT is on a distinguished road
321K on 2004 v8 cats
I did get a cat code last winter/spring a couple times below 40 degrees, but it would go away if it warmed up that same day. Guessing there's a small leak I couldn't seem to find, but ordered DT long tubes and a MF Y-pipe. Will most likely be installing headers this fall. Got one of those "Last sets" of DT longtubes I always read about.
Eibach pro truck with WOR springs on 1st notch in front. 5100's in rear w/ FJ OEM takeoff coils. 255/70R18 on 18" Limited wheels. 1.5" spacers on rear(one trimmed a bit to correct lean). Gibson catback, 06+Headlamps, auxito 16K bulbs in high, low, and fogs!
HIMILESV8SPORT is offline   Reply With QuoteReply With Quote
Old 07-24-2023, 05:20 PM #7
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Yeah check for the donut leak first. I bought replacements and got the passenger side on first and the stock with 225k miles looked perfect.. but the exhaust donut looked bad. Just barely enough to cause the light to come on. Now I don't know if I should just replace the other and go from there and scrap the OEM cats for cash..
gaber6 is offline   Reply With QuoteReply With Quote
Old 07-24-2023, 05:27 PM #8
I’m in your camp on this one. Especially now that we don’t have emissions anymore I’m less worried about it. It’s more I’m tired of clearing the codes.
Old 07-24-2023, 05:40 PM #9
MikeinNH67's Avatar
MikeinNH67's Avatar
Exactly, it's hard to tell if there's something really worthy of looking at going on.
Mike
03 4runner Limited
Old 01-28-2025, 04:12 PM #10
Gigachad Gigachad is offline
Gigachad is on a distinguished road
How was your experience switching out the cats? Also, do you know if theres a way to identify whether the cats are OEM or aftermarket? I recently bought an 04' v8 with P0420 & P0430 and am trying to identify whether an exhaust leak, bad downstream sensor or if the cats really are bad.
Gigachad is offline   Reply With QuoteReply With Quote
Old 02-16-2025, 09:14 PM #11
truckmike26 truckmike26 is offline
truckmike26 is on a distinguished road
There's a reason O.E. converters (and aftermarket ones with sufficient precious metals) are like five to 10 times the price of the cheap ones. Looking on Rock Auto, I'm curious if the $1,000+ aftermarket manifold/converters match or come close to originals.
'94 Pickup Xtra-Cab V6/Auto 4WD
'09 4Runner SR5 V6 4WD
'21 Tacoma TRD Off-Road
truckmike26 is offline   Reply With QuoteReply With Quote
Old 02-18-2025, 01:57 PM #12
alia176 alia176 is offline
alia176 has a spectacular aura about alia176 has a spectacular aura about
I too am experiencing 420 and 430 as of two months now but I did in fact have exhaust leaks at the connection point. These are "catalyst below threshold" fault codes, meaning there's excessive oxygen present past the cats, and the last O2 sensor is picking it up. The upstream o2 sensors don't care about the cats as they're technically AFR (air fuel ratio) sensors and don't throw this code.
In my case, I did fix the leaky exhaust, then reset the codes, and they're were gone for few days and now they're returned so i need to figure out how fresh air is getting introduced into the exhaust system. I'll do a smoke test this weekend to see if I can find the leak. I used all new hardware and donut gaskets for this project last weekend so I'm really annoyed at these two codes!
I have DT shorty headers + magnaflow California cats and no codes for the last six years. Aftermarket cats are not as good as OEM when it comes to longevity but they do the job just fine if your engine isn't dumping excessive fuel out of the cylinders and into the cats. Unburned fuel burns decreases the lifespan of cats or running too lean does the same thing.
Here's my exhaust thread in case you're curious Exhaust refresh - DT shortys + Magnaflow cross pipe
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
aftermarket , install , recommend , sensor , spacers
Air Fuel Ratio Sensor and o2 Sensor Replacement - P0136 and P2195 Smurray 4th Gen T4Rs 5 02-25-2019 08:21 PM
Air-Fuel Ratio (A/F) Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) vipblades 3rd gen T4Rs 33 10-25-2014 11:06 AM
Truth about MASS AIR SENSOR and THROTTLE BODY SPACERS preacher35 4th Gen T4Rs 3 05-14-2014 03:45 PM
2000 4Runner - A/F Sensor... O2 Sensor... California Exhaust but Federal ECU...Help! vandettaz 3rd gen T4Rs 0 03-16-2014 03:47 PM
