Old 08-04-2023, 11:11 AM #1
aa040371 aa040371 is offline
aa040371 is on a distinguished road
Items to Inspect/Replace Along with Rear Shocks?
I'll be replacing rear shocks in near future on my 2007 6-cyl RWD 4Runner w/~150K miles. It's a pretty straightforward maintenance item as far as I can tell.
Q: Are there any components or items, especially suspension related (e.g. bushings) that I should make sure to inspect or go ahead and replace since I'll be there with car jacked up and wheels off and wrenches out?
aa040371 is offline   Reply With QuoteReply With Quote
Old 08-04-2023, 11:21 AM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Inspect the control arm bushings for the rear axle for cracks or obvious wear. There are lower and upper control arms, they should be pretty obvious when you look under there.
Check the rear axle brake lines for cracked rubber. There are 2 lines from the body to the axle near the gas tank and then 2 smaller lines at the calipers. Replace as needed and honestly, with around 150k miles, I'd replace them as preventative maintenance.
Make sure the breather for the rear axle is clean. It's located on top of the axle, slightly to the left of the center section. Cap will be a little wobbly which is normal.
Not much else to check or worry about under there, just give everything a good visual inspection, issues should be pretty obvious. Wouldn't hurt to change the rear diff oil if it's not been done in a while.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 08-04-2023, 04:06 PM #3
MikeinNH67's Avatar
MikeinNH67's Avatar
I'll add looking around the rotors for axle leakage. The rear axle seals are getting old. The plus side in your area is no rust to look for.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
items , rear , related , shocks , suspension
Replacing CV axles again - what else should I replace/inspect? utmba95 4th Gen T4Rs 1 04-11-2021 05:15 PM
3rdgen replace rear OEM coils & shocks BUT papabear1126 3rd gen T4Rs 8 05-26-2017 09:11 PM
Rear Shocks - Remove and Replace Atlanta_man 4th Gen T4Rs 10 12-22-2013 07:18 PM
Can i replace the front strut assembly and rear shocks myself? 97T4RL 3rd gen T4Rs 4 07-27-2012 04:43 PM
How to replace rear shocks/struts tpirman 5th gen T4Rs 4 05-23-2011 11:48 PM
