Real Name: Todd
Real Name: Todd
Inspect the control arm bushings for the rear axle for cracks or obvious wear. There are lower and upper control arms, they should be pretty obvious when you look under there.
Check the rear axle brake lines for cracked rubber. There are 2 lines from the body to the axle near the gas tank and then 2 smaller lines at the calipers. Replace as needed and honestly, with around 150k miles, I'd replace them as preventative maintenance.
Make sure the breather for the rear axle is clean. It's located on top of the axle, slightly to the left of the center section. Cap will be a little wobbly which is normal.
Not much else to check or worry about under there, just give everything a good visual inspection, issues should be pretty obvious. Wouldn't hurt to change the rear diff oil if it's not been done in a while.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
