Old 08-09-2023, 08:09 AM #1
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
ABS control module and odometer connection
my brake lights have been on full time for a long time. took the vehicle in for a diagnosis. result was faulty ABS control module. had to get an inspection in the spring, failed due to brake lights not flashing. discovered that if i unplug the ABS module, the brake lights function normal. does cause a several dash lights (check engine/abs/brake). thankfully that is not cause an inspection rejection.
however, driving around like this, i noticed the odometer is not moving. i surmise that the speed sensors are offline, and those feed info to the odometer. i suppose running it like this will have no negative consequences. it is one way to keep the miles down!
rwh963 is offline   Reply With QuoteReply With Quote
abs , brake , lights , module , odometer
New ARB Pressure Control Module Mudhorn 5th gen T4Rs 1 12-03-2020 01:11 PM
ABS control Module help! Brian Keeler 3rd gen T4Rs 11 10-02-2019 08:04 AM
Where is the VSC control module? MONST4R 5th gen T4Rs 1 06-29-2016 10:46 PM
Ignition Control Module Identify Want to Buy/Trade 0 09-23-2012 03:04 PM
Ignition Control Module Identify Want to Buy/Trade 0 09-23-2012 02:56 PM
