I got the P0158 O2 Sensor Code about a week or 2 after I replaced both secondary cats. I’m not sure if that had anything to do with it or it’s just coincidence. I know the O2 sensor in question (Bank 2 Sensor 2) is before the new cats.
Is the best way to deal with this is just replace the sensor and hope the check engine light goes away? Or is there others things I can do to troubleshoot the issue? I’ll check the wire harness this weekend and see if I can clean up the sensor.
Bank 2 Sensor 2 is the driver side rear most sensor, after the cat, on the V6.
If you replace the sensor, use only Denso or OEM sensors. Denso is the OEM manufacturer for Toyota, so they are basically the same. Most other sensor manufacturers are a hit or miss as to working or how long they work. Same thing with the cats. Aftermarket is cheaper, sure, but they likely won't last as long as the OEM cats. Toyota uses better materials than any aftermarket does.
__________________ 2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
