Old 08-11-2023, 05:04 PM #1
Dr. Taha Dr. Taha is offline
Dr. Taha is on a distinguished road
Ecm replacement
Hello friends
I have 2008 4runner v8 AWD
had a problem with multi sensor (loss of communication with YAW-LATERAL ACCELERATOR- STEERING ANGLE SENSORS) with non erasable codes & OBD II DEVICE couldnt get any POWERTRAIN codes (can not get to engine).
Did everything can be done with no success.
Finally decided to try replacing the ECM with a one from junk yard.
The PART number not the same but also 4runner v8 AWD CAR.
THE OBD II had the access to the engine & read codes of the immobilizer and get into ABS & cleared all the codes.
My concern is
if I programmed the immobilizer with ECM with the different part # can i loose other options on the vehicle.??
& if i got same part number for the same car model & specifications and reprogram it to my immobilizer is it ok or there is also a chance to loose some options??
Thank you
Dr. Taha is offline   Reply With QuoteReply With Quote
Old 08-13-2023, 08:32 PM #2
hankd's Avatar
hankd hankd is offline
Real Name: Harry
hankd is on a distinguished road
hankd's Avatar
Real Name: Harry
when i went through this i made sure to buy the identical part. i was tempted to see if other v8 awd computers would work, but i waited it out on ebay and before too long there was a listing at a decent price for the exact part. once i got the immobilizer programmed, the truck worked exactly as it did before.
i can't remember if i had to reprogram the tpms when i did that.
the thing that worries me about ecu mismatch is incremental changes toyota is making to the vehicle year over year. for example added vvti to the v8, fixed hg issue on v6. i've seen at least one thread where somebody ran into ecu incompatibility issue because of swapping seemingly identical engines from diff years or models. usually with the ecu threads i've seen, the ecu will not light up a scanner whatsoever. and then people think it is something else at first.
anyway it's possible it might work? especially if your obd2 scanner is recognizing the vehicle and giving the immobilizer code. i don't exactly have the warm fuzzies about it tho haha
hankd is offline   Reply With QuoteReply With Quote
Old 08-14-2023, 09:09 AM #3
Big thanks for you dear.
Have you changed the immobilizer with ECU or just reprogrammed the previous immobilizer with the new ECM?
Old 08-16-2023, 04:13 AM #4
@AuSeeker
Need your opinion please.
Old 08-16-2023, 05:41 PM #5
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Unfortunately I don't know the answers to your questions....that being said I would always replace ECMs with the same part number as the original, otherwise you're just inviting further issues.
2004 Limited V8
Old 08-16-2023, 06:07 PM #6
Thats exactly what I needed to hear.
Thank you
Old 08-18-2023, 06:34 PM #7
Dutchy82 Dutchy82 is offline
Dutchy82 is on a distinguished road
Wow thais is what we may be experiencing right now.. I flooded my truck 06 limited.. Got it running on the Orginal ecu then boom.. now it all of a sudden won't start, and won't connect to a scanner and I'm trying to find out if it's my ecu or immobilizer.. Pulling my hair out currently.
Sent from my SM-G975W using Tapatalk
Dutchy82 is offline   Reply With QuoteReply With Quote
codes , ecm , engine , immobilizer , part
Auto Trans Shifter Bushing Replacement & Transfer Case Shifter Seat Replacement mtbtim 3rd gen T4Rs 17 09-14-2022 08:23 PM
Lower Ball Joint replacement or dust boot replacement help? dot_tom 5th gen T4Rs 7 01-11-2018 11:52 PM
xreas replacement - shock vs shock/spring replacement amheck 4th Gen T4Rs 21 11-14-2017 08:21 PM
3rd Gen 4runner Rear Coil Spring Replacement and Rear Shock Bushing Replacement mtbtim 3rd gen T4Rs 7 11-28-2016 11:43 AM
CV boot replacement vs entire joint replacement zerowkul98 Maintenance/Detailing 3 06-29-2010 06:30 PM
