Old 08-21-2023, 01:55 AM #1
Sean7 Sean7 is offline
Sean7 is on a distinguished road
Can you help me figure out where this sound is coming from?
Hi everyone,
I was wondering if anyone can listen to this here and tell me what they think is causing the sound? (almost sounds like metal rubbing or grinding?)
Sound clip here
The sound is coming from the front side of the car (to me it sounds like it's from the passenger side) and seems to only happen when I'm going above 10-15 mph and stops at much higher speeds (30+).
I haven't noticed any vibration or any change in the steering. I did have a minor leak from the steering rack which stopped after I used the stopleak.
My first guess was a loose or bent brake dust shield. I got under the car and touched it and it seems pretty solid with no movement. Should I jack up the car and take the wheel off to inspect the dust shield properly?
What do you think it may be (wheel bearing maybe?) and what tests should I perform to track down the issue?
Sorry for the long post. If it helps, this is a 2006 V8 with 168K miles on it.
Sean7 is offline   Reply With QuoteReply With Quote
Old 08-21-2023, 05:30 AM #2
GreenMountainOwl GreenMountainOwl is offline
GreenMountainOwl is on a distinguished road
Exhaust heat shield vibrating? To me it’s definitely a metal-on-metal sound.
GreenMountainOwl is offline   Reply With QuoteReply With Quote
Old 08-21-2023, 10:19 AM #3
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of
Bluesky 07's Avatar
Sounds rotational but you can never tell for sure. Removing the wheel and rotating the rotor should help determine if that’s the issue. If not, heat shield would be my next guess.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 08-21-2023, 12:30 PM #4
Thank you both for the suggestions. Exhaust heat shield was not on my guess list but I'll definitely check it out.
I'm waiting for my new jack stands to arrive and then I'll be taking off the wheel to inspect farther as Bluesky 07 suggested.
I will update back soon
car , shield , side , sound , sounds
Head is spinning trying to figure out sound dampening Rushthezeppelin 3rd gen T4Rs 10 07-18-2023 10:12 AM
Help me figure out this sound! cbelisle 4th Gen T4Rs 5 06-18-2018 02:03 PM
Help me figure out this truck sound (with video) sounds like ... Wtf not good BrianSD_42 3rd gen T4Rs 20 10-19-2015 08:40 PM
What is this sound in my dash? I can't figure it out piccrazy30 4th Gen T4Rs 4 05-30-2014 07:02 PM
Cant figure out this sound. 99'4runner 3rd gen T4Rs 1 11-09-2010 12:22 PM
