Old 08-21-2023, 08:59 PM #1
0verland's Avatar
0verland 0verland is offline
0verland will become famous soon enough 0verland will become famous soon enough
0verland's Avatar
Question Suspension Refresh
Hello!
As the title says, it's come to that time where my '06 needs a suspension refresh. I installed new SPC UCAs and OME lift kit replacing both front and rear shocks. I opted to delay replacing other components i.e. lower control arms, sway bar bushings, end link bushings, etc since the dry desert has taken its toll on my rubber bushings.
So as I started down the rabbit hole to do a full refresh of all my bushings it have run into a lot of conflicting information and lack of information from manufacturers. I am looking to replace nearly everything with new or upgraded parts and wanted to get some input on what everything is using?
I planned on replacing the bushings in the majority of the stock components with Energy Suspension poly bushings, but I am more than open to other options. If anyone can suggest some good replacements or upgraded to get things riding like new or better again.
Thanks in advance for the feedback.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
0verland is offline   Reply With QuoteReply With Quote
Old 08-21-2023, 09:32 PM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Look into SuperPro. Excellent (and preferable over Energy Suspension IMO) quality urethane bushings with proven reliability. I'm using them on my 2003 V8 4Runner and have been extremely happy with them. LCAs are SuperPro offset bushing, stock replacement LCAs and have been awesome. The offset allows you to move the front wheels further forward in the wheel well and gain some caster while making room for larger tires.
If you want to upgrade the rear UCA/LCAs, look into the MetalTech offering for those. I have them on my truck and they have been great.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 08-25-2023, 06:54 AM #3
T4r.Chris's Avatar
T4r.Chris T4r.Chris is offline
T4r.Chris is on a distinguished road
T4r.Chris's Avatar
Originally Posted by 0verland View Post
Hello!
I can only speak on the sway bar bushings from Energy. They are sweet, greatly improved feeling on those long freeway turns. Haven’t noticed any difference off-road with them either, stress tested them on a trail and noticed no difference in wheel travel/flex. Only PITA is you have to order them custom if you do front and rear as they don’t make a kit. But now have grease-able front/rear sway bar bushings.
Depending on your budget, some aftermarket end links are worth it too. I went with Overland Custom Designs Heim Joint Endlinks, adjustable and appear much more durable long-term.
2005 4Runner SR5 - Build Thread- https://www.toyota-4runner.org/4th-g...ld-thread.html
T4r.Chris is offline   Reply With QuoteReply With Quote
bushings , information , refresh , replacing , suspension
Suspension Refresh daprotege5 4th Gen T4Rs 6 12-11-2022 10:11 AM
Suspension refresh kit? dcTR4 4th Gen T4Rs 6 11-28-2018 02:22 PM
Best value suspension refresh for on road use? TFin04 3rd gen T4Rs 21 06-30-2018 05:00 PM
Suspension refresh on 05 SR5 ThatSickRip 4th Gen T4Rs 7 12-21-2017 09:06 PM
Front suspension refresh radlynx 4th Gen T4Rs 2 03-03-2017 04:20 PM
