Old 08-26-2023, 07:42 PM #1
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Steering rack metal transfer lines?
Salt Life has claimed one of my rack transfer lines at 282k miles in NJ, the ones that go from the rack to the steering head. Two rust bubbles that ruptured outward and are spraying fluid as shown in the pic (engine off dribbling).
These are not the lines that run to/from the pump, they are the two which are attached to the rack itself.
Toyota does not sell these separately from the rack. Not finding aftermarket options.
Any ideas or suggestions appreciated, it's deadlined.
I also see similar early warning signs on one of the transmission pipes leaving the case (I replaced the cross-pipes a few years back when one rusted out). These are readily available so I'll do both while I'm in there, along with the power steering pump lines.
Steering rack metal transfer lines?-img_0851-jpg
waypoint is offline   Reply With QuoteReply With Quote
Old 08-26-2023, 10:29 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
You maybe able to used brake line type fittings and tubing to replace the power steering lines if you can find the correct size fitting and tubing, or look for a shop in your area that specializes in hydraulic lines and they maybe able to make them for you.
2004 Limited V8
Old 08-27-2023, 07:34 AM #3
waypoint's Avatar
waypoint's Avatar
Good feedback as always, greatly appreciated. I'm getting a heavy duty flare wrench and crows-foot today to help get the existing tubes off the rack, this will be my go/nogo step. If they come off, the project is line replacement...if not, it's steering rack replacement.
I found a local NAPA open on Sunday which lists hydraulic hose fab, will call them when they open. Otherwise there are several shops in nearby cities open on weekdays. If the tubes come off, I'll get new ones fabbed in stainless steel.
Plan B: car-part.com lists a few salvage yards with steering racks available for ~$150 and up, and I can inspect them before purchase. If my current 282k mile rack comes out, it's not going back in.
I'm also going to replace the pump supply & return lines while it's opened up, they're factory and nasty looking despite years of Fluid Film, Woolwax, etc. I'm the second owner and it spent the first 10 years with no treatment, but decent car washing as the guy owned 3 car wash places. The stuff above the skid plates was the only rust I found...horizontal salt spray while driving, but only vertical wash spray.
Old 08-28-2023, 06:17 AM #4
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
did you check this, also tried rock auto? power steering pressure hose?
Power steering tube for Toyota 4Runner GRN215L - Genuine parts
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 08-28-2023, 02:58 PM #5
FerdTerg FerdTerg is offline
FerdTerg is on a distinguished road
Any luck with a solution for this? I’m having a similar leak and I don’t want to replace the whole rack.
FerdTerg is offline   Reply With QuoteReply With Quote
Old 08-29-2023, 08:47 AM #6
waypoint's Avatar
waypoint's Avatar
Update: the fitting broke at the rack while trying to loosen the transfer tube, even after Kroil soaking and modest torch heating. It's getting a rack.
I'll add pics of the transmission cooler tubes which show early signs of the same failure due to rust weakening the external surface, looks like a bulge on a tire sidewall waiting to rupture. Lots of road salt here in NJ, and these pipes are above the skidplates...they get horizontal spray while driving, but the vertical spray at the car wash does not wash them effectively.
Old 08-29-2023, 08:59 AM #7
Bummer. I live in PA so very similar road salt situation. I already had to replace the transmission cooler lines and the power steering return due to rust. I’ve got 168,000 miles on mine. Starting to get some frame rust too. Not sure how much longer I’m going to keep it. Still runs perfect and I love it but I don’t want to dump a bunch of money into a 17 year old truck.
Old 08-29-2023, 05:17 PM #8
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
Broke how? Isn't that setup similar to a brake line nut? If so, I generally cut the line close to it and stick a proper 6 point socket on it to remove. Then you can get the old tube out even if it has to be drilled out. BTW, I like copper nickel tubing as it doesn't rust and is super easy to work with.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 08-29-2023, 09:09 PM #9
waypoint's Avatar
waypoint's Avatar
Woolwax on the metal that doesn't get direct road spray, and CRC Marine Corrosion Inhibitor on the ones that get sprayed. Drop the skids once a year, hit the radiator support crossmember inside & out. Frame rails, any exposed metal.
Old 08-29-2023, 09:14 PM #10
waypoint's Avatar
waypoint's Avatar
Cracked at the elbow into the rack housing. I considered cutting the tube and using the impact gun, but I really needed that line intact so I could get a replacement fabricated.
I'm about halfway into pulling the rack and it's not horrible work. Going to replace the steering shaft as the U-joint is pretty fragged even with years of layered Fluid Film, then later switched to Woolwax.
lines , pump , rack , steering , transfer
DIY 2008 V8 Steering Rack install including new PS Pump and all new lines randy88fj62 4th Gen T4Rs 0 01-17-2022 02:03 PM
Power Steering Rack Lines 4runnerWiniarski23 3rd gen T4Rs 15 04-25-2019 07:30 AM
Power Steering Rack Removal: How do I get the pressure lines off?? nobb 3rd gen T4Rs 27 03-08-2019 12:05 PM
Aftermarket High Pressure lines OEM Steering Rack? nc-grayson 3rd gen T4Rs 11 12-19-2017 12:41 PM
Sourcing the hard lines on the back of the steering rack xcmountain80 3rd gen T4Rs 19 09-09-2014 01:53 PM
