Originally Posted by soundmanlpte
Thanks for the response. Would getting the fuel pressure checked help narrow down the issue? If fuel pressure is low, does that eliminate injectors as the cause?
Yes, it could potentially narrow down the issue. When you have that checked, they should be able to point you more closely to either a fuel pump related issue or injectors or potentially both.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
