10-03-2023, 08:10 PM
#16
Originally Posted by riceandpho
tires and tire pressure might be the problem, I was loaned a 04 or earlier tacoma when my truck was in for all that work, once I hit 70, I felt the truck shake also, that tacoma had off road type of tire and different wheels, I just kept it under 70 on my way home from the shop.
Google Maps
It was almost all alliviated by dropping the psi to 35. This is the cause of the vibration.
Steering still has some play, (in fact more than i think is normal) and im going to update on tie rod situation soon. Just in case someone else has this issue down the line. In fact it may have brought forward a new issue: Steering clunks sometimes when turning (just does at random points while turning) and something makes a loud crunch when moving in reverse.
Thank you all for the help!
Sent from my SM-G973U using Tapatalk
10-04-2023, 08:58 AM
#17
drop it down to 34, do it when its a cold tire, hope you click the link of the google map, that was the truck that was loaned to me so I can be at home when they perform the work. I only live a few exits away, I didn't check the air pressure since it is not my vehicle. pretty sure it was high.
since they added so much air in your tires, pretty sure you were just bouncing everywhere, also you'll notice that the middle of the tire had more wear.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
10-04-2023, 04:50 PM
#18
I'd check that steering shaft u-joint for this noise. It can feel/sound different at certain points of rotation because of the joint being angled.
I'd also check the u-joints on the rear driveshaft as they can clunk when going into gear. If one of those fails, especially the front one, it can become an expensive repair. Chock the wheels, put the car in neutral and check for play in both u-joints.
Glad to hear the bouncing is fixed.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
10-05-2023, 01:16 PM
#19
Replace your steering u-joint.
Also, you didn't say whether your American Racing wheels are hub-centric or not....this is one of the major reasons why you get vibrations even with brand new wheels and tires.
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
10-06-2023, 08:53 PM
#20
I regret to inform everybody it is not the tires. Tires at 35 psi make right pull more noticeable, and the shaking worse. It does not go away 75+.
However it does come and go more noticeably.
The first two runs i had reported zero vibration.
This one trip was particularly shaky. Steering would "dive" over bumps.
To answer some questions i beleive the american racing rims are lug centric, they dont fit like the old rims do. So i think theyre lug centric.
10-07-2023, 07:01 PM
#21
Having owned three 4-gen runners and seen this issue to some degree on each one, I would say that having the vehicle aligned and your wheels meticulously balanced goes a long way toward solving it. An alignment is very simple, because with a fixed rear axle there's nothing to do except up front. And I don't know why it's so, but a 4Runner is incredibly sensitive to proper wheel balance ... maybe they are set up with a little less caster than most roadgoing vehicles; that's all that occurs to me.
The big chain shops do a pretty mediocre job of alignment and balance; best to take it to a local specialist, or even bite the bullet and go to a dealer, and get it bang-on once and for all.
I've been having an issue with my 4runner where she starts to get very skittish starting at around 60. Either she reeally doesn't like I-80 or something's up.
Basically once you get up to 60 the steering wheel starts to vibrate, then around 65 ish a front end vibration shows up. This front end vibration varies in intensity and seems to come and go, you can feel it in the steering wheel and floor and the front of the car starts to wander around while pulling right.
It gets worse until about 70 where it peaks and the front end feels loose and it starts jerking around unpredictably (especially while turning left it seems), before calming down past 75+ and remaining as a wobble and slight right pull.
I have jacked the vehicle up to see if there was anything was loose in the steering system/suspension only a very slight side to side motion in the FR wheel. However it was incredibly minor, and I'm not sure if it would cause a vibration so severe.
On occasion I can hear a faint metal pinging when it gets really bad. But that hasn't happened in a long while.
Any help is much appreciated.
10-08-2023, 01:09 AM
#22
since tire pressure helped a little bit, I'm suspecting an unbalance wheel and bad alignment, just because you did the alignment 4000 miles ago, something could happen, also road condition too.
tire pressure should of help with the skidding since they maxed out with that 50-60 psi. that's why I said to drop it to 34.
now the steering, have to check the alignment again, pretty sure the toe needs to be adjusted, hopefully your camber and caster is good too.
even when they finished the toe adjustment, they might need to tweak a side to compensate the pulling of a side.
if you don't plan on going to the shop anytime soon, rotate your wheels in an X pattern. see if that changes anything. that might tell you a wheel is off balance.
10-10-2023, 04:53 PM
#23
If the wheels are lug-centric then you need to take it to a shop that can actually do a proper lug-centric balance on the wheels...it's an actual fixture with 6 fingers at 6x139.7 that can properly place it in the holes of the wheel....probably a bad explanation but that's all I got. Look it up.
It's best to start with a quick call or message to American Racing to determine whether or not the wheels are actually lug centric.
