Old 10-02-2023, 09:58 PM #1
knightsfs4's Avatar
knightsfs4 knightsfs4 is offline
knightsfs4 is an unknown quantity at this point
knightsfs4's Avatar
Which Sway Bar Links Are You Using?
I found some older threads with info on this, but wanted to see if there were any updated opinions for the best set of Sway Bar Links for 4th gens.
I've read good things about these: Forged Ball Joint Sway Bar Links
– Overland Custom Design
Any other good options out there that you would recommend?
Knightsfs4 Build Thread http://www.toyota-4runner.org/4th-ge...ld-thread.html
Jack-Purchased on 11/22/10- 2006 Limited 4X4 V8
knightsfs4 is offline   Reply With QuoteReply With Quote
Old 10-02-2023, 10:52 PM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
None, I don't have sway bars.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 10-03-2023, 01:47 AM #3
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
When I had my front swaybar, I used OCPTY from Amazon. With a part with a job so simple, I decided not to go crazy with the spending on them. I think I paid like $50 for 4 of them. Even on my last build, I used cheapo endlinks and never had issues with them.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 10-03-2023, 05:19 AM #4
miller507's Avatar
miller507 miller507 is offline
miller507 will become famous soon enough
miller507's Avatar
3rd gen end links at the rear and normal links at the front.
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
miller507 is offline   Reply With QuoteReply With Quote
Old 10-03-2023, 09:15 AM #5
LOSTR4's Avatar
LOSTR4 LOSTR4 is offline
LOSTR4 will become famous soon enough LOSTR4 will become famous soon enough
LOSTR4's Avatar
Front or rear or all? I made my own with some Hillman hardware, stainless steel all-thread and some Energy Suspension bushings and they've been terrific and adjustable a little bit...
From Energy Suspension:
Part Number: 9.8121
Product Name: Universal Sway Bar End Links 98121
Part Number: 9.8105
Product Name: Sway Bar End Link Grommets and Washers - 98105
From Hillman Group:
The Hillman Group 59655 3/8x1/2x1-1/2-Inch Seamless Steel Spacer
Amazon has all this stuff too...Find some 3/8" SS all thread and away you go! Some cutting and threading the parts on...easy to do and a fraction of what you could spend...
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
LOSTR4 is offline   Reply With QuoteReply With Quote
Old 10-03-2023, 10:29 AM #6
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
I made my own sliding disconnects for the front. They are OK, not great. The gain from them is mainly a smoother ride off road. Can't say I'd recommend it unless your looking for a project.
During the winter, I have some basic Moog ones I put on the front. They work well enough.
For rears, I use Pathfinder endlinks. Beefier than stock, and longer, which helps compensate for my lift.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 10-04-2023, 12:01 PM #7
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
2nd gen links in the rear, pull the front off.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 10-08-2023, 11:59 AM #8
FoundedSine14's Avatar
FoundedSine14 FoundedSine14 is offline
FoundedSine14 will become famous soon enough
I have the Overland Custom Design sliding front disconnects and I absolutely love them. I've made my own links for the rear, similar to LOST4R
Sent from my Pixel 5 using Tapatalk
2008 SR5 | Build Thread
FoundedSine14 is offline   Reply With QuoteReply With Quote
bar , good , links , set , sway
Sway Bar Links KwonRunner 4th Gen T4Rs 5 03-12-2021 01:18 AM
Sway bar links BunBun 3rd gen T4Rs 3 04-06-2019 08:22 AM
Front sway bar removal and extended rear sway bar links. morphious 4th Gen T4Rs 25 11-29-2015 01:36 PM
Sway bar links Coopsdaddy 3rd gen T4Rs 3 11-23-2014 10:31 AM
