Old 10-08-2023, 02:45 PM #1
sport2004's Avatar
sport2004 sport2004 is offline
Real Name: James
sport2004 is on a distinguished road
sport2004's Avatar
Real Name: James
Another..."What's that noise?" Thread
'04 Sport, 6 cyl, 4WD, 157,000 mileage
Noticeable left front whining/whirring sound 15-20 mph, then a bit louder up to about 50 mph, still there, but then the road noise drowns it out. Noticed a barely detectable scraping sound recently, similar to what might come from the wheel hub, when coasting 15 mph (have to turn the radio off to hear it).
No problems steering/turning, braking, stopping, alignment, suspension (far as I can tell). I thought it could be a bad tire. They are year-old Michelin Defenders, about 10K on them. The sound is similar to lousy tires with 20K on them, something Michelins don't do, unless it's a bad tire, which I guess is not unheard of.
Brake job all around at 110,000 miles, front left caliper replaced, about ready for new pads all around, so that can't be ruled out.
What's wrong doctor? Thanks for any ideas.
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
sport2004 is offline   Reply With QuoteReply With Quote
Old 10-08-2023, 03:52 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Jack it up and check your wheel bearings to see if they're bad or to rule them out.
2004 Limited V8
Old 10-08-2023, 04:46 PM #3
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
^^^^^ Thank you, Skip, appreciate you chiming in, as always. Did a search here and discovered the bearings could be the culprit. I've also looked at a few websites/videos discussing the options. I don't have the means to jack it up in my driveway, though a relative would do it if I lived closer to him. When I start calling around tomorrow I'll know as much, or more, about the job than the shop guy.
The other thing about the bearings, which I've read here before, and now verified elsewhere, is to make sure the replacement parts are not Chinese. Hoping I can pull that off in my communications with the shop. Thanks, again.
Regards, sport2004
Old 10-08-2023, 05:40 PM #4
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Does the noise stop when you step on the brakes?
OEM front rotors?
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 10-08-2023, 05:52 PM #5
Real Name: Skip
Real Name: Skip
James,
I just purchased new wheel bearing/hub assemblies for my T4R, I got mine from NAPA, I purchased the only ones they sell with a "Limited Lifetime Warranty", so if they go bad I can get them replaced for free, they were actually slightly cheaper than their "NAPA" brand and they are only warrantied for one year.
2004 Limited V8
Old 10-08-2023, 06:16 PM #6
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
OEM front rotors?
No, the only thing that stops it is when you vehicle slows down and stops. Use of the brakes has no effect on the sound.
I suspect the rotors are OEM since I got a hold of the work record of the first owner, all at a dealership. Got the records from a dealer in Canada.
Regards, sport2004
Old 10-08-2023, 06:18 PM #7
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Originally Posted by AuSeeker View Post
James,
Good to know, thanks.
Regards, sport2004
Old 10-09-2023, 10:11 AM #8
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
If that L/F isn't getting hotter than the R/F I think you can rule out the brakes. With it being a constant noise that varies with speed but braking doesn't stop it then I too agree with it being a wheel bearing. I would pull the bearing on that wheel and replace it. If that stops the noise I would also replace the R/F. It's not necessary but that's me; belt and suspenders.
Rich
Kentucky
Old 10-09-2023, 10:47 AM #9
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
James,
+1 for the NAPA hubs, that's what I went with as well after a lot of research. They offer a military/veteran discount too if you happen to be eligible.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 10-09-2023, 02:25 PM #10
Bob22222 Bob22222 is offline
Bob22222 is on a distinguished road
James,
The parts are warranted (maybe they'll honor it) but in any case, the big part of that, labor, is on your dime (or your time if you have the equipment and are capable.
Just get a high quality, oem quality, Japanese made bearings and hub assembly.
Bob22222 is offline   Reply With QuoteReply With Quote
Old 10-09-2023, 06:38 PM #11
Real Name: Skip
Real Name: Skip
I do all of my own work and yes they will replace them for free, with using the complete hub/bearing assembly it doesn't take very long to swap the assembly out.
2004 Limited V8
Old 10-09-2023, 06:45 PM #12
Real Name: Skip
Real Name: Skip
I paid for mine online and picked them up the next day at my local NAPA store, I got lucky and they had a 20% off any purchase over $200 so I saved $88+ by ordering online.
2004 Limited V8
Old 10-10-2023, 07:43 AM #13
MrWeatherman's Avatar
MrWeatherman MrWeatherman is offline
MrWeatherman is on a distinguished road
While youíre doing that, grease up the driveshafts. Couldnít hurt to do some preventative maintenance.
MrWeatherman is offline   Reply With QuoteReply With Quote
Old 10-10-2023, 09:13 AM #14
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
^^^ Will do, thanks.
Regards, sport2004
Old 10-10-2023, 12:42 PM #15
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Can someone say now long this job takes in your garage or at a shop? Thanks...
Regards, sport2004
mph , noise , similar , sound , tire
The "Noise" thread- Descriptions and Fixes** Billynath1988 4th Gen T4Rs 3 09-09-2017 10:32 PM
cacarbuff's "Build Thread" but really it's a "Run Thread" :D cacarbuff 4th Gen T4Rs 19 03-10-2014 12:47 AM
Faint "whirring" noise, then a click (under passenger side of truck) Riders of Lohan 3rd gen T4Rs 14 02-25-2013 04:23 AM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
"creaking" noise in my passenger rear area...just bought my 4Runner today! Help paulnohio 4th Gen T4Rs 8 10-31-2005 10:46 AM
