Originally Posted by SocalSam
Ebay weather strips are in. As with most things in life, you get what you pay for. Fronts went in easy enough and fit well. Rears fit OK. "Vent" glass cutouts could be tighter so there is enough gap to let water in. Rear clip is slightly out of position so the fit on the sill is not as good as the front. It is passable for a road warrior like mine.
Overall, value for money is there for a T4R that (proudly) shows its miles. If your T4R is in nice cosmetic condition, you could get by with these but OEM would be better.
One thing you need to understand about those "belts"/weather strips they were never designed to keep all water out, it's impossible since the glass is not a fixed glass, they are designed to keep some water out but mostly to keep debris and insects from getting in, there are drains in the bottom of all the doors and tailgate to allow any water that gets in to drain out, if you ever hear water splashing around inside a door or tailgate hours after it has rained it's because the drains are clogged and need to be cleaned.
