Old 10-19-2023, 11:03 AM #1
mtbtim's Avatar
mtbtim mtbtim is online now
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Rear Axle Seal / Bearing Replacement
Hey Dudes,
This video shows you how to perform a Rear Axle Seal / Bearing Replacement on your rig using a SST (Special Service Tool) made by my buddy Duane who makes them out of his home in Omaha, Nebraska.
This is Part 1. Part 2 will be coming out soon.
mtbtim is online now   Reply With QuoteReply With Quote
Old 10-19-2023, 11:03 AM #2
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
PART 2
Old 10-20-2023, 09:38 AM #3
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
It's a bear of a job.. using the tool was an absolute life-saver, but man.. the 20 ton press was STRUGGLING getting the bearing onto the nitro axles I decided to upgrade to. I bent quite a few things in the process lol.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 10-20-2023, 11:44 AM #4
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Maybe the Nitro axles aren't quite right. The spec only needs to be off a little to make a huge difference. My guess is the diameter of the shaft where the bearing rides is off by a few thousands. The bearings do fit fairly tight onto the OEM axles, but my 20 ton press didn't load up hardly at all pressing the bearings on.
Do you have a link to those Nitro axles? I'm guessing the reason for the upgrade is they are considered stronger than OEM?
Old 10-20-2023, 01:40 PM #5
yea they are chromoly axles. I decided while I was doing the bearings I may as well spend a few hundred bucks extra and go with the nitro axles since I'm fuly locked and on 35's.
I agree that it could be something as silly as the coating being slightly thicker than stock, but man.. it was a struggle. lol
Toyota 8" Nitro Rear Chromoly Axle
Old 10-22-2023, 09:43 AM #6
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Part 2 is now live! Check out Post #2.
axle , bearing , rear , replacement , seal
Rear Axle Seal / Bearing Replacement mtbtim 5th gen T4Rs 7 10-22-2023 09:45 AM
Rear Axle Seal and Bearing Replacement? ChromeT4R 3rd gen T4Rs 23 06-01-2021 10:34 PM
Rear Axle Seal/Bearing Replacement Videos mtbtim 3rd gen T4Rs 104 10-10-2020 04:06 PM
Rear axle seal/bearing replacement RS Dude 3rd gen T4Rs 53 06-11-2016 12:46 PM
Rear axle seal/bearing replacement RS Dude 3rd gen T4Rs 2 04-11-2016 12:41 PM
